How can I make notification without an obligation to close the problem?
  • awrow
    • May 2020
    • 16
    I need to receive a notification when authentication on the client happens. I have an item with key:
     log[/var/log/auth.log,(sshd.*)?(Accepted)]
    Also I have trigger with key:
     {test.test.ru:log[/var/log/auth.log,(sshd.*)?(Accepted)].str(Accepted,#1)}=1
    I need that there will be only notification without raising a problem. With my config I always should deactivate the problem and I receive a second notification I don't need. How can I make notification without an obligation to close the problem or to receive second notification?
  • Hamardaban
    • May 2019
    • 2714
    The best thing to do is to read the documentation and understand the relationship between triggers, events and notifications.
    https://www.zabbix.com/documentation.../config/events
    https://www.zabbix.com/documentation.../notifications
    In short: a trigger always triggers an event (problem) - but not every event triggers an notification.
    • awrow
      • May 2020
      • 16
      Hamardaban do u mean OK event generation = None setting on a trigger tab? It still makes the problem instance in the Problems log. How can I do what I need without making a problem or something close to that?
      • awrow
        • May 2020
        • 16
        I got it! Thanks! When I started this my trigger was caught by already existed action instance. And that action instance had recovery operation steps. So all I needed was to create another action instance with no recovery steps.
