SNMP Item not working for Cisco ME-3400-24TS-A
  • Nehemoth
    • Apr 2020
    Trying to monitor a switch using SNMP.
    Followed up the documentation about how to create an item for a SNMP agent which can be found here.
    After several tries, I am still not been able to see/gather the status for the desired information.
    Did a snmp walk
    snmpwalk -v 2c -c HEADEND MY_Switch_IP_Address
    It gave me a lot of info from where I took what interest me
    SNMPv2-SMI::mib-2.47.1.2.1.1.8.11 = STRING: "vlan-825"
    SNMPv2-SMI::mib-2.47.1.2.1.1.4.11 = STRING: "HEADEND@825"
    SNMPv2-SMI::mib-2.47.1.2.1.1.2.11 = STRING: "vlan825"
    SNMPv2-SMI::mib-2.47.1.1.1.1.7.1008 = STRING: "FastEthernet0/2"
    SNMPv2-SMI::mib-2.47.1.1.1.1.2.1007 = STRING: "FastEthernet0/1"
    SNMPv2-SMI::mib-2.47.1.1.1.1.2.1002 = STRING: "ME-3400-24TS-A - Fixed Module 0"
    SNMPv2-SMI::mib-2.47.1.1.1.1.2.1003 = STRING: "ME-3400-24TS-A - Power Supply 0"
    SNMPv2-SMI::mib-2.47.1.1.1.1.2.1004 = STRING: "ME-3400-24TS-A - Fan 0"
    from where I took one
    snmpget -v 2c -c HEADEND -On 172.24.31.199 SNMPv2-SMI::mib-2.47.1.1.1.1.2.1004
    which gave me
    .1.3.6.1.2.1.47.1.1.1.1.2.1004 = STRING: "ME-3400-24TS-A - Fan 0"
    With that information I went to the host items, create a new one as follows:
    Type: SNMPv2 Agent
    Key: SNMPv2-SMI
    SNMP OID: .1.3.6.1.2.1.47.1.1.1.1.2.1004
    SNMP Community: My_COMMUNITY
    Type of Information: Numeric (unsigned) [also I tried with numeric {float}]
  • Hamardaban
    • May 2019
    • 2714
    Is there anything wrong with that?
    and
    • Nehemoth
      • Apr 2020
      Originally posted by Hamardaban
      Is there anything wrong with that? and ?
      Nice way to makes me see the error but I tried character (and even log and text) but I got the same result.
      Having said that, maybe I need to look out for the same item but with another type of data.
      Thank you for the answer.
      • Hamardaban
        • May 2019
        • 2714
        And actually what error do you get (the red icon in the info field of the problem data element)?
        What is written in the server logs?
        • Nehemoth
          • Apr 2020
          I believe you put me in the right path.
          After the previous post I change the item to be monitored, now I'm getting some information.
          my command
          snmpget -v 2c -c HEADEND -On My.IP IF-MIB::ifInOctets.10004
          what I'm getting from the cli
          .1.3.6.1.2.1.2.2.1.10.10004 = Counter32: 410041180
          How I created the item
           Type: SNMPv2
          Key: SNMP-InOctets
          SNMP OID: .1.3.6.1.2.1.2.2.1.10.10004
          and finally what I'm getting (graphically) : 410041180
          So
          as right now I believe my issue it's understanding what I'm monitoring.
          After all a hardware can have only 2 values, working or not / there or not.
          The documentation it's great so I believe I will continuing digging and see how can I find the desired information, if this case to know if a port it's working or not.
          @Hamardaban really appreciate the help
