Zabbix Items show ZBX_NOTSUPPORTED
  • syd05
    • Dec 2014
    I've configured some checks on Zabbix servers for my infra. One of which is a check for tomcat. The key for the item is "proc.num[java,tomcat,,tomcat7]"
    On servers that have tomcat running the check works perfectly fine. On servers that don't have tomcat running I would expect it to return a value of 0 but in this case it returns ZBX_NOTSUPPORTED. Logically I would assume that ZBX_NOTSUPPORTED would refers to incorrectly configured items. But here the item & key are correct but is shown as ZBX_NOTSUPPORTED.
    If I change the key to proc.num[java], it returns a 0 & that is what I would also expect of the above mentioned key. Can this be achieved or is it a default behaviour that cannot be changed? I would like to see it changed so that there is a distinction between incorrectly configured keys that are actually not supported or have a syntax error & checks that should return a zero as in the case above.
    --Syd
