Zabbix Redhat RPM Configuration options?
  • gleepwurp
    • Mar 2014
    • 119
    I have my Zabbix Environments currently running off of the Zabbix pre-compiled RPMs. I have a small patch to apply to fix the Web Monitoring portion of the Zabbix server, and I'm planning on manually replacing only the executable.
    Does anyone know which "./configure" options are set for the binaries inside the zabbix_server.rpm package? I'd like to keep the same options and hopefully not miss any important options that are currently enabled in the RPM package.
    Thanks!
    G.
  • jan.garaj
    • Jan 2010
    • 506
    Check source RPM (e.g. http://repo.zabbix.com/zabbix/2.4/rhel/6/SRPMS/) and zabbix.spec file in the source RPM. Basic common flags:
    %if %{build_server}
    common_flags="
        --enable-dependency-tracking
        --sysconfdir=/etc/zabbix
        --enable-server
        --enable-agent
        --enable-proxy
        --enable-ipv6
        --enable-java
        --with-net-snmp
        --with-ldap
        --with-libcurl
        --with-openipmi
        --with-jabber
        --with-unixodbc
        --with-ssh2
        --with-libxml2
    • gleepwurp
      • Mar 2014
      • 119
      Thank you Jan!
      This is exactly what I was looking for!
      G.
