Zabbix 5 and PHP
  • zendx
    • May 2020
    • 12
    Zabbix 5 and PHP
    Hello!
    I want to upgrade from version 4.4 to version 5.
    I already have PHP 7 installed. Apache is installed also
    Why is Zabbix 5 bound to packages of a specific repository?
    Is it possible to somehow install Zabbix 5 frontend without using SCL repository?
    It is very uncomfortable.
    Instead of just installing the Zabbix package and using the already installed httpd and php, I need to install PHP from the SCL repository, and with it a separate Apache package (because PHP from SCL wants the Apache from SCL).
  • tim.mooney
    • Dec 2012
    • 1430
    Using SCL is the only officially-supported way to get PHP 7.2 on RHEL or CentOS 7.x. Because the PHP package names differ from core OS, Zabbix provides a set of package that use the SCL packages.
    However, did you read the upgrade guide for RHEL/CentOS ? Did you see the "Note"?
    If you read that documentation fully, they provide an option for people that don't want to use SCL.
