Hello.
Can't install zabbix 5.
After entering command
# rpm -Uvh https://repo.zabbix.com/zabbix/5.0/r...el8.noarch.rpm
# dnf clean all
# dnf install zabbix-server-mysql zabbix-web-mysql zabbix-apache-conf zabbix-agent
Last metadata expiration check: 0:15:01 ago on Sat 16 May 2020 02:52:47 AM EDT.
Error:
Problem 1: conflicting requests
- nothing provides libcrypto.so.1.1()(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
- nothing provides libcrypto.so.1.1(OPENSSL_1_1_0)(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
- nothing provides libssl.so.1.1()(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
- nothing provides libssl.so.1.1(OPENSSL_1_1_0)(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
- nothing provides libssl.so.1.1(OPENSSL_1_1_1)(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
- nothing provides libevent-2.1.so.6()(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
- nothing provides libnetsnmp.so.35()(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
- nothing provides libssh.so.4(LIBSSH_4_5_0)(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
- nothing provides libmysqlclient.so.21()(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
- nothing provides libmysqlclient.so.21(libmysqlclient_21.0)(64bit) needed by zabbix-server-mysql-5.0.0-1.el8.x86_64
Problem 2: conflicting requests
- nothing provides libcrypto.so.1.1()(64bit) needed by zabbix-agent-5.0.0-1.el8.x86_64
- nothing provides libcrypto.so.1.1(OPENSSL_1_1_0)(64bit) needed by zabbix-agent-5.0.0-1.el8.x86_64
- nothing provides libssl.so.1.1()(64bit) needed by zabbix-agent-5.0.0-1.el8.x86_64
- nothing provides libssl.so.1.1(OPENSSL_1_1_0)(64bit) needed by zabbix-agent-5.0.0-1.el8.x86_64
- nothing provides libssl.so.1.1(OPENSSL_1_1_1)(64bit) needed by zabbix-agent-5.0.0-1.el8.x86_64
Problem 3: package zabbix-web-mysql-5.0.0-1.el8.noarch requires zabbix-web = 5.0.0-1.el8, but none of the providers can be installed
- conflicting requests
- nothing provides php-bcmath >= 7.2 needed by zabbix-web-5.0.0-1.el8.noarch
- nothing provides php-fpm >= 7.2 needed by zabbix-web-5.0.0-1.el8.noarch
- nothing provides php-ldap >= 7.2 needed by zabbix-web-5.0.0-1.el8.noarch
- nothing provides php-mbstring >= 7.2 needed by zabbix-web-5.0.0-1.el8.noarch
- nothing provides php-gd >= 7.2 needed by zabbix-web-5.0.0-1.el8.noarch
- nothing provides php-xml >= 7.2 needed by zabbix-web-5.0.0-1.el8.noarch
Problem 4: package zabbix-apache-conf-5.0.0-1.el8.noarch requires zabbix-web, but none of the providers can be installed
[root@zabbix lib64]# uname -a
Linux zabbix 3.10.0-1062.el7.x86_64 #1 SMP Wed Aug 7 18:08:02 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
[root@zabbix lib64]# ls -la
total 0
drwxr-xr-x. 2 root root 6 Apr 11 2018 .
drwxr-xr-x. 12 root root 131 May 15 05:52 ..
[root@zabbix lib64]# pwd
/usr/local/lib64
can anybody help?
# dnf clean all
Error:
total 0
/usr/local/lib64
can anybody help?
