I am trying to write a discovery rule for finding XFS project quotas using the `/etc/projects` file.
The file is very simple like this:
What I need is to get the paths and fetch them using LLD macros, or that is my plan....
I thought I could use
vfs.file.contents[/etc/projects]
then a regex to match
then turn it into JSON... but the regex only seem to match the 1st line and stop. I could not manage to give it the global modifier.
I would like to avoid running shell scripts to manipulate the text into JSON but it may be the only way perhaps. Is there any better way?
Thanks!
20:/tmp 30:/home 40:/var/crash 50:/var/tmp 60:/var/log 70:/var/lib/postgresql/
\d+:(.*)
Thanks!
