SSL Certificate Zabbix fronend Centos8
  • medharrak
    • Jun 2018
    • 31
    Hi all,
    I have Zabbix 4.4.8 running on Centos 8 , I tried to configure auto signed SSL following the "zabbix 4.4 manual", but it's not working , any idea why ?
    The following is my configuration
    yum install mod_ssl
    mkdir -p /etc/httpd/ssl/private
    chmod 700 /etc/httpd/ssl/private
    Country Name (2 letter code) [XX]:
    State or Province Name (full name) []:
    Locality Name (eg, city) [Default City]:
    Organization Name (eg, company) [Default Company Ltd]:
    Organizational Unit Name (eg, section) []:
    Common Name (eg, your name or your server's hostname) []:192.168.56.103
    Email Address []:
    -I Edited /etc/httpd/conf.d/ssl.conf
    DocumentRoot "/usr/share/zabbix"
    ServerName 192.168.56.103:443
    SSLCertificateFile /etc/httpd/ssl/apache-selfsigned.crt
    SSLCertificateKeyFile /etc/httpd/ssl/private/apache-selfsigned.key
    - I Edited /etc/httpd/conf/httpd.conf
    And I added at the end the following :
    <VirtualHost *:*>
    ServerName zabbix-server
    Redirect permanent / http://zabbix-server
    </VirtualHost>
  • doogie
    • May 2020
    • 16
    Make it easier for yourself and use letsencrypt with the apache module then you get a valid certificate.
    Instructions here: https://certbot.eff.org/lets-encrypt...l8-apache.html
    Then you'll have a valid certificate plus it'll setup everything for you.
    Cheers,
    Doogie
    • medharrak
      • Jun 2018
      • 31
      LetEncrypt needs domain name configured , I don't have domain name , I connect to the server with it's IP.
      • CafeMan
        • Feb 2021
        Hi, I have same problem.
        Did you solve it somehow? Did you solve it somehow? Thx
        • medharrak
          • Jun 2018
          • 31
          Hi, No still not , I haven't get any help in this forum
          • wojtech
            • Feb 2021
            Hey, I am not Linux specialist, but have you verified that your web (GUI) is running on httpd (Apache) and not nginx?
            When you install mod_ssl it also installs httpd if the package does not exist, so if your webserver is running on nginx then it will not accept httpd config files.
            You can verify which webserver is listening on 80 port running this command:
            ss -tlnp | grep -E ":80\b"
            or maybe this one:
            ss -tulpn | grep :80
            You can also try to find a manual on the web how to configure SSL on Centos nad httpd / nginx, you don't have to stick to the Zabbix manual.
