MySQL 'random' shutdowns since Zabbix installed
  • slydog
    • Oct 2014
    • 16
    A couple weeks ago I installed Zabbix 2.2.6 server on a RHEL 6.2 (x86_64) host. The particular server runs MySQL 5.1 on it, and has had very active MySQL databases running on it for more than a year without any problems at all.
    Since I installed Zabbix using packages and following the Zabbix.com installation instructions at .../documentation/2.2/manual/installation/install_from_packages we have had 3 or 4 unexpected shutdowns of MySQL. According to the mysqld.log a shutdown command has been issued at the time of each outage. A couple days ago the log showed
    141218 20:46:51 [Note] /usr/libexec/mysqld: Normal shutdown
    141218 20:46:51 [Note] Event Scheduler: Purging the queue. 0 events
    141218 20:46:53  InnoDB: Starting shutdown...
    141218 20:46:55  InnoDB: Shutdown completed; log sequence number 0 93867942
    141218 20:46:55 [Note] /usr/libexec/mysqld: Shutdown complete
    141218 20:46:55 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
    I have examined all the possible cronjobs on the server; and have examined the EVENTS tables in MySQL; but have found nothing that indicates where this shutdown command is originating. I have also been able to find any evidence of someone issuing a shutdown command while logged into the host.
    Any help figuring this out will be much appreciated!
  • slydog
    • Oct 2014
    • 16
    Is it possible that one of these php configuration settings could be triggering the MySQL shutdown command?:
    php_value max_execution_time 300
    php_value max_input_time 300
    They are added to
    /etc/httpd/conf.d/zabbix.conf
    as part of the installation.
