Web Monitoring - Triggers
  • singhn
    • May 2019
    • 16
    Hi All,
    I have created 1 web scenarios under Temple Web Monitoring.
    I have created one trigger using hard-coded values.
    Now, I am adding few more web scenario, and I would like to multiple triggers.
    Is there any inbuilt variables that i can use for Alert name & expression for response code without having to create triggers individually?
    I searched the forum but i didn't find an example with variables for expression & alert name.
    Appreciate your direction & assistance on this.
  • Mike2K
    • Oct 2018
    • 60
    Could you please provide us with some examples of what you're trying to do ?
    • singhn
      • May 2019
      • 16
      Sure Mike2k,
      I would like to create a trigger prototype using response code that applies to all scenario. When I get an email alert or problem alert, it would like it to fill up the scenario name automatically. Something similar to low disk space alerts which state Disk Space on Drive xyz is under x%
      • Mike2K
        • Oct 2018
        • 60
        Ohhh, you're looking for macro's.
        Be sure to select your zabbix version!
        • singhn
          • May 2019
          • 16
Name:	2020-05-20 16_23_28-ClientPC - VMware Workstation.png
          I have 4 web scenarios in web monitoring template, applied to zabbix server. I checked the reference link but only found 3 reference to scenarios. I am running ver 4.4
          4 Supported since Zabbix 2.2.0, {HOST.*} macros are supported in web scenario Name, Variables, Headers, SSL certificate file and SSL key file fields and in scenario step Name, URL, Post, Headers and Required string fields.
