How to utilise nodata
  • bilal.habib
    • Apr 2020
    • 22
    Hi i have the current expression
    HTML Code:
    {OKTA AD Agent Status:service.info[Okta Active Directory Service].min(#3)}<>0
    This works fine however i would like to add nodata alert into it so when there is no data the trigger is triggered. Could you explain nodata to me please?
  • Mike2K
    • Oct 2018
    • 60
    So you could do something like:
    {OKTA AD Agent Status:service.info[Okta Active Directory Service].nodata(30)}=1
    That'll trigger when there's no data received in the last 30 seconds (you should probably set this value a bit higher)
    • bilal.habib
      • Apr 2020
      • 22
      Originally posted by Mike2K
      https://www.zabbix.com/documentation...gers/functions
      Thanks going to do test this
