Zabbix database tables
  • GeorgeKup
    • Nov 2019
    • 98
    When a zabbix server is installed, then in MySQL we deal only with Innodb tables and, accordingly, with the settings for these tables. But for some reason, in a number of examples, I present settings for both Innodb tables and Mysiam tables. Can someone explain why?
  • GeorgeKup
    • Nov 2019
    • 98
    For example, for Mysiam there are such parameters: key_buffer_size, sort_buffer_size, read_buffer, write_buffer.
    • tim.mooney
      • Dec 2012
      • 1432
      I don't understand what you mean by this question:
      Please remember that even if your 'zabbix' database is only using InnoDB storage engine, MySQL/MariaDB still has some MyISAM tables for its own tables, like mysql.host, mysql.user, etc.
      If I run the following query on my MariaDB 10.2.22 server that is used only for Zabbix:
      select table_schema as database_name, table_name, engine
          from information_schema.tables
      where  table_schema not in ('performance_schema')
      order by table_schema, table_name;
      The output shows that many of the MySQL/MariaDB "internal" tables still use MyISAM.
