Item values for a time period in Email notification
  • vicious
    • May 2020
    Hi everyone,
    Please suggest if\how can I implement the following.
    I have text-type item.
    I want to put that item's value for a period of time (let's say, for last 10 minutes) into email notifications.
    Thanks in advance.
  • aib
    • Jan 2014
    • 1615
    dirty trick - use some last values in trigger expression and then put {ITEM.VALUE1-9} to message template
    Sincerely yours,
    Aleksey
    • tim.mooney
      • Dec 2012
      • 1436
      Read up on what macros can be used in different locations: https://www.zabbix.com/documentation...ed_by_location
      For your case, pay particular attention to {ITEM.VALUE<1-9>} and especially {ITEM.LASTVALUE<1-9>}. I don't actually think either of these are quite what you want (though maybe they will work for you), but if you read the comments about the macro being an alias to a macro with a .last() function and then scroll to the bottom of the macro list, you'll see you might be able to use something like
      {{HOST.HOST}:{ITEM.KEY}.last(#2)}
      {{HOST.HOST}:{ITEM.KEY}.last()}
      etc.
