Zabx 2.4.1 on Debian 7.7 64bit
  • pantera
    • Dec 2014
    • 39
    dpkg -i zabbix-release_2.4-1+wheezy_all.deb
    apt-get update
    apt-get install zabbix-server-mysql zabbix-frontend-php
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    zabbix-frontend-php is already the newest version.
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
     zabbix-server-mysql : Depends: libiksemel3 but it is not installable
                           Depends: libopenipmi0 but it is not installable
                           Recommends: snmpd but it is not going to be installed
                           Recommends: snmptt but it is not installable
    E: Unable to correct problems, you have held broken packages.
    What I should do?
    I'm newbie on Zabbix
