monitor https status is failed
  • Aaron_Yu
    • May 2020
    • 26
    I have a web site, and I want to monitor https port status of it.
    But it's failed.
    error info:
    Support for HTTPS check was not compiled in.
    The http is ok.
    What do I should?
  • Hamardaban
    • May 2019
    • 2714
    Are you using net.tcp.service? Simple check or agent key?
    Anyway - build / install libcurl with https support!
    Or try net.tcp.port instead of just checking the port is available.
    • Aaron_Yu
      • May 2020
      • 26
      This is my key:
      net.tcp.service[https,,443]
      try net.tcp.port[,443] is ok.
      • duyth4
        • Apr 2020
        If you want to monitor your website, I would recommend making a template with simple check "net.tcp.service[tcp,<your website IP address>,80]", "net.tcp.service[tcp,<your website IP address>,443]" and a website scenario.
        After that, link that template to your Zabbix Server, remember to open port for your Zabbix Server connect to your website.
        • Hamardaban
          • May 2019
          • 2714
          Run curl -V and show output here.
          • Aaron_Yu
            • May 2020
            • 26
            Run curl -V on web Server or zabbix?
            • Hamardaban
              • May 2019
              • 2714
              It depends on the answer to the question you ignored: «Simple check or zabbix agent key?»
              • Aaron_Yu
                • May 2020
                • 26
                this is my key:
                • Hamardaban
                  • May 2019
                  • 2714
                  There are 2 keys of the same spelling, but different in the type of data element - “Simple checks“ OR “Zabbix agent”
                  Please look at the TYPE parameter field of the data element with the net.tcp.service[https,,443] key
