Zabbix graphics and alarms for this particular situation
  • emper0r
    • May 2020
    • 27
    Hi community
    I created this script in powershell
    PS C:\Users\user> ps -IncludeUserName|? UserName -m "$env:USERNAME" | sort -Descending cpu | select -f 10 | ft -AutoSize
    the output is
    Handles WS(K) VM(M) CPU(s) Id UserName ProcessName
    599 46456 324 3.169,28 4120 DOMAIN\user1 fshoster32
    2079 88860 577 2.072,28 3416 DOMAIN\user2 explorer
    353 69308 680 89,66 2660 DOMAIN\user3 InetMgr
    210 25916 127 82,11 7728 DOMAIN\user4 notepad++
    762 83928 383 36,13 8212 DOMAIN\user5 iexplore
    581 33496 190 30,89 3420 DOMAIN\user6 iexplore
    300 11496 253 27,56 5804 DOMAIN\user7 taskhostex
    316 10096 91 20,00 8156 DOMAIN\user8 rdpclip
    418 80240 640 9,31 1112 DOMAIN\user9 powershell
    147 7204 95 4,31 1372 DOMAIN\user10 ClassicStartMenu
    I need to get this text as is in and get it in the alerts message send it by email when occurs for example load average in server reach 10 to know who is and take action, is possible?
    and when I execute on windows works.
    c:\Zabbix\bin\get_process_users.ps1
    in configuration agent I got
    UserParameter=GetProcessUsers,c:\Zabbix\bin\get_pr ocess_users.ps1
    I restart ok the agent on windows but can't get anything on linux server
    $ zabbix_get -s 192.168.1.100 -p 10050 -k "GetProcessUsers"
    no output
    $ zabbix_get -s 192.168.1.100 -p 10050 -k "system.run[powershell.exe -File 'c:\Zabbix\bin\get_process_users.ps1']"
    Processing -File ''c:\Zabbix\bin\get_process_users.ps1'' failed: The given path's format is not supported. Specify a valid path for the -File parameter.
    Windows PowerShell
    Copyright (C) 2016 Microsoft Corporation. All rights reserved.
    In the other hand I need put this information in a grapfic to see in the history line if some users put the load times ago either.
    it's possible this too?
    thanks in advance for any help
  • emper0r
    • May 2020
    • 27
    Hi
    I create an item but can't still receive the data...
    if I type wrong I receive the lines because is broken but if I type correctly just get null response. take a look into attachment
    thanks
