I need to create action that will be activated at most once per time period, problem is that this action can be generated from 5 hosts
for example, you have 5 pc, when one of them freezes, only option is to restart it, it can be done with restarter connected throught ethernet, but problem is when 2 or 3 PCs freezes at once, it generates 3 triggers and so 3 actions of same type... so the restarter will get 3 commands to restart...
is there way to restrict action for executing maximum once per time period from last activating? for example maximum one action of that type per 5 minutes
