I can't find any information about if it's possible to make your own templates and add to Zabbix. We have a lot of servers that looks exactly the same, but I don't need to monitor everything in the default templates. Can I make my own templates and if I can, where do I find these templates and how do I add another one?
Is it possible to make your own templates?
Under COnfiguration -> Hosts there is a drop down box (near the top right side) that lists Templates as one of the options to view. Choose that, then you can click Create Template and then go for it! If you create the template and it doesn't show up, make sure you have the Group box selected properly (I've stumped myself a few times forgetting about that..wondering where my template went..) -
Not only that but now they even have a forum just dedicated to templates that we can dowload.Originally posted by ameliaI can't find any information about if it's possible to make your own templates and add to Zabbix. We have a lot of servers that looks exactly the same, but I don't need to monitor everything in the default templates. Can I make my own templates and if I can, where do I find these templates and how do I add another one?Comment
