Secure Installation of Zabbix
  • unnikrishnan
    • Mar 2014
    Hi All,
    Does Zabbix provide a https URL for downloading the package. The official doc is mentioning a normal http doc
    Ref: https://www.zabbix.com/documentation..._from_packages
    Also, Is it possible to identify if the following ppa maintainer is an official one:
    The packages in this repo are simply the latest Trusty packages backported to Saucy and Precise. No other modifications have been made. Updates may be a little intermittent but I'll try to keep up.
    A bit concerned about the security aspect.
    Regards
    Unni
  • timbo
    • Sep 2013
    • 50
    Hi Unni,
    [Note: I deleted my original reply as I misread Unni original question]
    You seem to be right, I cannot find a https link for the packages. Perhaps Zabbix have the file hashes published somewhere as they do for the pre-compiled agents:
    http://www.zabbix.com/download.php
    -Timbo
    • unnikrishnan
      • Mar 2014
      Thanks for checking this Timbo.
      However, the hash from the same http link won't be much helpful, right?
      So the next possible option is to go for PPA installation, right?
