Zabbix SAML Meatdata URL
  • jbanner6736
    • May 2020
    Trying to setup Zabbix 5.0.1 with SAML Login and I cannot for the life of me find the metadata url for zabbix?? Does anybody know what it is, it only has the assertion and logout url's in the documentation. Onelogin's saml-php says it should be at metadata.php or ?metadata but nothing works, we need the metadata for the zabbix service provider in order to use saml.
  • jbanner6736
    • May 2020
    I managed to fix this myself, turns out via JIRA, Zabbix doesn't natively have a metadata url nor does it have a service provider metadata file which is odd being SAML and is how SAML works :/
    Step1: Created Metadata
    <?xml version="1.0" encoding="utf-8"?>
    <EntityDescriptor entityID="https://monitor.example.edu" xmlns="urn:oasis:names:tc:SAML:2.0:metadata">
        <SPSSODescriptor protocolSupportEnumeration="urn:oasis:names:tc:SAML:2.0:protocol">
            <AssertionConsumerService Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST" Location="https://monitor.example.edu/index_sso.php?acs" index="0" />
            <SingleLogoutService Binding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-Redirect" Location="https://monitor.example.edu/index_sso.php?sls" />
            <NameIDFormat>urn:oasis:names:tc:SAML:2.0:nameid-format:transient</NameIDFormat>
        </SPSSODescriptor>
       <Organization>
          <OrganizationName xml:lang="en">Your Organization Name</OrganizationName>
          <OrganizationDisplayName xml:lang="en">Zabbix Network Monitor</OrganizationDisplayName>
          <OrganizationURL xml:lang="en">http://monitor.example.edu/</OrganizationURL>
       </Organization>
       <ContactPerson contactType="administrative">
          <GivenName>System Administrator</GivenName>
          <EmailAddress>[email protected]</EmailAddress>
       </ContactPerson>
       <ContactPerson contactType="support">
          <GivenName>Tech Support</GivenName>
       </ContactPerson>
    </EntityDescriptor>
    Step 2: Added Alias under DocumentRoot tag in Apache to Metadata file on Zabbix Server that is placed at /var/www/html
    Alias "/zabbix-metadata.xml" "/var/www/html/zabbix-metadata.xml"
    Badda bing, Zabbix now has a service provider metadata url. Adding Zabbix as a relying party to ADFS or Shibboleth is easy peasy.
    • Gblaze56
      • Nov 2020
      </SPSSODescriptor>
      <Organization>
      </Organization>
      </ContactPerson>
      </ContactPerson>
      </EntityDescriptor>
      Thanks Jbanner! Looks very helpful, in ubuntu where is the DocumentRoot for zabbix? I've tried Grepping and can't really find it
      update: through trial and error I found it in /etc/apache2/sites-available/000-default.conf
