Disable same trigger, created bij discovery rule in template, on multiple hosts
  • area54
    • May 2020
    I have been reading a lot but just registered because I have a question I cannot find the answer to.
    We have a lot of network devices, all have items and triggers created by a template. Lots of triggers are created by trigger prototypes in a discovery rule.
    At the moment the devices are having a firmware upgrade and there seems to be a bug in there which sends false SNMP data causing some triggers to fire.
    What I want is to temporary disable all those triggers on all the hosts using this template.
    I can not disable it in the template because it is a discovery rule so only creating the triggers enabled or disabled but not changing them when discovery runs, if I understand correctly.
    So my question: Is it possible to disable the same trigger on multiple hosts at once? And how do I do that? (I want to enable them later when the firmware bug is solved)
