Zabbix default value.
  • patrickdenis
    • May 2020
    • 18
    Hi all,
    Is it possible to change or add to the default value ?
    Example : the refresh value are 10sec , 30s, 1m ,10m 30m etc.... i would like to add 1sec in these drop option for the interval refresh.
    Thank you in advance.
  • stemconnect
    • Nov 2021
    I am interested in a solution to this. In my case I would like to remove the 10s option.
      https://github.com/zabbix/zabbix/blo...s.inc.php#L908 if you talk about dashboard refresh frequencies...
      But what in all things holy makes you want to refresh every second.. ? What does it give you ? Noone's looking at that so often anyway... Or you just think your webserver has too little work to do?
