Zabbixx monitoring HP Server
  • Aaron_Yu
    • May 2020
    • 26
    I have a hp server and use zabbix monitoring it's ILO by Template Server HP iLO SNMPv2.
    Now it have a probles in the dashboard, this erro information is "System status is in critical state."
    but I check the ILO of the server, the status is OK, that don't have any error.
    what do I do?
  • Aaron_Yu
    • May 2020
    • 26
    This problems is log history.
    The server has a hard disk failure, then it has been fixed.
    But, the problem record always in the log.
    Can I do anything other than delete logs?
    • tim.mooney
      • Dec 2012
      • 1436
      Does the problem (event) that was generated allow you to click the "Close problem" checkbox and resolve the issue that way?
      • Aaron_Yu
        • May 2020
        • 26
        it isn't allow.
        Can I create a trigger that allow manual close?
        • chrisme
          • Sep 2016
          • 15
          I have the same problem today after importing the new zabbix 5.0 ilo template.
          The problem is the ilo log history.
          Go to the ilo webinterface and clear the logs. After that the trigger "System status is in critical state" go green.
          • wpagane
            • Apr 2021
            • 31
            Same issue here.
            Did you guys figure it out?
            • Juanra
              • Jul 2021
              I have the same problem, I think is a bad IOD in the template, because clear the log, and see the iLo web interface the system status OK
              The value i see in smnpwalk is 4 always. somebody know where fin a MIB of iLo4
              • Juanra
                • Jul 2021
                Edit: The OID es ok, when is ok have the number 2 and when the log is full (and others problems) is un number 4. But have to wait a couple of time to refresh the status.
                • Metalgalle
                  • May 2021
                  • 14
                  I resolved this issue selecting the error log line in the IML tab of the iLO interface, and then marked as "repaired" with the wrench icon button at the top of the log list!
                  • hkmix
                    • Aug 2022
                    i have cleaned the IML log via iLO, but in zabbix still showing system status is in critical state, how long will it take ?
                    • Metalgalle
                      • May 2021
                      • 14
                      I'm sorry hkmix for late reply.
                      Usually it takes a small amount of time, if you want to speed up the process, you need to force the discovery process for that item
                      • coda_matt
                        • Nov 2022
                        • 20
                        I had the exact same issue with Zabbix 6.2 and this solved it.
