JMX Monitoring Data Source in Weblogic
  • ShinigamiBG
    • Jan 2015
    I using Zabbix to monitoring weblogic server .I successfully monitor Java Heap and number of Threads.
    But now i want to monitoring Data Sources,are they Running or Suspended or is there are some problem with them.
    Attribute that i use is
    jmx["com.bea:Name=DataSourceName,ServerRuntime=soa_ser ver1,Type=JDBCDataSourceRuntime","State"]
    This Attribute shows me only when the DataSource is Running ,but when I stop the DataSource ,Zabbix tell me that he did not support "Suspend".
    Could you tell me where is the problem or how can I config Zabbix to monitoring DataSources.
    Regards
  • ShinigamiBG
    • Jan 2015
    I fix the problem .Just add a trigger which indicate only data source is Running or not .
    But now i want to monitoring a few composite in soa_server .
    Did any one know how to create such a jmx query
    • marco69v
      • Mar 2005
      i'm interested too
      • akbar415
        • May 2015
        • 119
        Post here your trigger.
        • Bruno Carvalho
          • Oct 2014
          • 32
          See my article: http://brunocarvalho.net/blog/2016/0...me-com-zabbix/
