Zabbix Inventory - Discovery OS
  • ComputerHabit
    • Jun 2020
    • 46
    Is the OS and other features of a system supposed to be discovered and populated? I turned on inventory for a system with the agent installed. It gathered inventory like services but the OS was never populated.
  • ComputerHabit
    • Jun 2020
    • 46
Name:	Annotation 2020-06-08 172721.png
    In this case the default isn't defaulting maybe.
    • ComputerHabit
      • Jun 2020
      • 46
      I'm reading this:https://blog.zabbix.com/inventory-co...n-zabbix/9242/
      I don't see what the blog is describing.
      • ComputerHabit
        • Jun 2020
        • 46
        All I understand from the articles is that inventory does nothing but get the name of the pc. I still don't understand if I can populate any of the other fields in inventory. The article suggested seems like its showing you something but its confusing and really doesn't seem like much of anything. Unless you want the hostname field to show a CPU value or something useless like that.
        • ComputerHabit
          • Jun 2020
          • 46
          I might be getting closer. It seems like some of the items I'm looking for might be there but I'm getting an error trying to use it.
Name:	Annotation 2020-06-09 102459.png
