How to configure time delay for zabbix mail trigger
  • moumita.das
    • Jun 2020
    We have mail notification configured from zabbix - most of the time if an issue occurs, within few minutes we get OK notification mail as well. Both increasing mail box unnecessarily. How to configure time delay like an alert will be generated > zabbix will wait for 30m to check if the issue resolved > if resolved, no alert mail will be sent, if not alert mail will be sent
  • aib
    • Jan 2014
    • 1615
    Check https://www.zabbix.com/documentation...on/escalations - Example 2. Use 30m instead of 10h for configuration of Operations
    Sincerely yours,
    Aleksey
    • moumita.das
      moumita.das commented
      Hi Aleksey, thank you so much for your response. I just had one doubt, suppose the incident got resolved within 30m, that is before sending the 1st delayed notification, will I get notification or not ??
    • aib
      aib commented
      I don't think so. See notes for Example 3: " Note that the manager will get a message only in case the problem is not acknowledged yet, supposedly no one is working on it."
