Move soket MariaDB for zabbix
  • GeorgeKup
    • Nov 2019
    • 98
    The / data section was created to which the database files from / var / lib / mysql were moved.
    The path for the MariaDB socket, /data/mysql/mysql.socket, was specified in the my.cnf file. In addition, the path to the new socket was specified in the zabbix.conf configuration file.
    The socket is created in a new location on the / data section and the database is started, only installing zabbix does not see the socket in the new location.
    Now the database is on the / data section, and the socket file on the other section is /var/lib.mysql. Do not tell me how bad it is that the socket file and the database are on the same server, but in different sections?
  • tim.mooney
    • Dec 2012
    • 1432
    You haven't caused any long-term problems, you just need to fix where the socket is created on startup.
    You need to make sure that the 'socket' setting is present in both the
    [mysqld]
    socket = /data/mysql.sock
    and in the
    [client]
    sections of your my.cnf. If it's only specified in the [client] section, that's not enough.
    If you're using an older version of MariaDB, you may also want to specify the socket setting in the [mysqld_safe] section.
    Once you've done that, restart. The MariaDB server should create the local connection socket in the correct place.
