Hello guys
Need your help/advise
I'm stuck on a particular problem with zabbix file monitoring
I've tested the concept on 2 machines to see if zabbix can pickup on a keyword in log file and it works, whenever specific word (defined by me) appears in the log file we get an email
Now, the problem/error I'm getting is:
SSH-2.0-OpenSSH_5.9p1 Debian-5ubuntu1.4
Protocol mismatch.
On machine where zabbix server is installed I have:
Linux version 2.6.32-431.3.1.el6.x86_64 ([email protected]) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-4) (GCC) ) #1 SMP Fri Jan 3 21:39:27 UTC 2014
OpenSSH_5.3p1, OpenSSL 1.0.1e-fips 11 Feb 2013
And machine where zabbix agent lives (the one where I'm trying to monitor the log file)
Linux version 3.2.0-69-generic (buildd@lamiak) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #103-Ubuntu SMP Tue Sep 2 05:02:14 UTC 2014
OpenSSH_5.9p1 Debian-5ubuntu1.4, OpenSSL 1.0.1 14 Mar 2012
It matches the error message. So the way I see it zabbix server tried to check on an agent but gets rejected because of protocol mismatch. I've searched google inside out but cannot find anything that helps, I also updated every single module to do with ssl/ssh on both machines, no luck, zabbix is still throwing the same error, protocol mismatch, I know it works because I tested it but it's refusing to work on this particular machine. Every other aspect of monitoring is fine apart from log files, can anyone help? Or maybe suggest something?
Thank you
Protocol mismatch.
Thank you
