Macros in Trigger expressions
  • Tenou
    • Feb 2020
    • 17
    Hey there,
    I'm trying to implement macros in trigger expressions. This way it'd be possible to assign discovered items to "groups" with different thresholds, without having to define every single threshold manually.
    However, when adding a macro to a trigger expression, zabbix is complaining about syntax errors.
    Is there a way to do this properly?
  • Hamardaban
    • May 2019
    • 2714
    Pls show trigger expression.
    What type of macros are you using?
    • Tenou
      • Feb 2020
      • 17
      {1wire-temperature-probe:system.run[cat /sys/bus/w1/devices/{#DEVICE}/w1_slave | tail -n +2  | cut -d= -f2-].last()}>=30
      That would be the trigger expression in the current state of things.
      What I'd want to do with it is this:
      and
      {$GROUP:"{#DEVICE}"}=0
      or
      {1wire-temperature-probe:system.run[cat /sys/bus/w1/devices/{#DEVICE}/w1_slave | tail -n +2 | cut -d= -f2-].last()}>=40
      and
      {$GROUP:"{#DEVICE}"}=1
      {$GROUP:"{#DEVICE}"} being the context specific macro I was talking about.
      It's set as 0 by default ({$GROUP}=0 in the host tab), but you could override it by setting it manually for specific devices (eg. {$GROUP:"1481748147861"}=1).
      This way, by default the threshold for every device would be 30°C, but you could set it manually to 40°C without the hassle of disabling the existing triggers, configuring new ones etc.
      I hope you get what I'm trying to do. If not, feel free to ask!
      • Tenou
        • Feb 2020
        • 17
        Okay well.. It worked with the stuff I posted earlier today perfectly. There's no problem. I was just dumb. Sorry
