Services discovery Alarms after upgragrading Zabbix 4.4 to 5.0
  • froometgn
    • Jun 2020
    I just upgrade my Zabbix installation based on an Ubuntu 18.04 everything went ok, but I realize that all the host using the default "Template OS Windows" are sending me alerts with the service that are set up automatically and server not started, I disabled the discovery on the template as you can see below
    This is the configuration of the discovery rule
    I do not need that Zabbix check for these kind of services.
    How can I disable this?
    Thank you very much
    Best regards
