Error Zabbix Agent
  • MisterM74
    • Jan 2015
    Error Zabbix Agent
    good morning
    I'm new
    I have this error when I try to connect a server to monitor this:
    Received empty response from Zabbix Agent at [XXX.XXX.XXX.XXX]. Assuming that agent dropped connection because of access permiss
    I tried every configuration I've found on Google, nothing works.
    Even knowing that the hostname must match on the host machine.
    Thank you for your help
    Mz
  • GOID
    • Oct 2014
    • 35
    maybe incorrect ip address of ZabbixServer in conf file?
    Try connect via "telnet ip 10050" from server and from pc.
    post here your agent config.
    • MisterM74
      • Jan 2015
      error type Json
      cannot parse list of active checks: cannot parse as a valid JSON object: invalid object format, expected opening character '{' at: 'ZBX_NOTSUPPORTED'
      Good Morning
      Below, I have another type of error
      Is it in the configration file or just this error?
      Yours
      Michel
      • GOID
        • Oct 2014
        • 35
        Version of agent and server is same ?
        post here full error log and conf file.
        Maybe you set incorrect item key in agent config
        • MisterM74
          • Jan 2015
          Hello
          Zabbix Agent Version :
          zabbix_agent -V
          Zabbix agent v2.4.3 (revision 51175) (15 December 2014)
          Compilation time: Dec 18 2014 13:28:13
          Zabbix Server Version :
          zabbix_server -V
          Zabbix server v2.4.3 (revision 51175) (15 December 2014)
          Mz
