Hosts + geolacalizations + geomap + zoom
  • Rudlafik
    • Nov 2018
    • 165
    Exist live project for integration geo positions of hosts to Zabbix map (use openstreetmap, googlemaps)? I would like on Z5LTS start map function and geolocalizations our IP cam. And integrate 1500 hosts from csv file and others. Plus use zoom function. Is it scifi? :-) (I found only ZabGeo from 2017y works on Z3.4) Do you recomend me your best practice? How do you solve this problem?
    Ruda
  • Flyerman
    • Jan 2021
    geomap was in roadmap for 5.4, now it's moved to 6.0, that's not good This is "must have" for us.
    P.
    • Rudlafik
      • Nov 2018
      • 165
      on the contrary, that's good news! We need work with metrop cameras systems and public inteligent streetlight + LAN/WAN systems. Good luck hat the project will succeed.
      Rudlafik
