Impossible to install SNMPTT on Centos 8
  • Shahin
    • Jun 2020
    [SOLVED]
    I would like to use SNMPTT in order to receive traps coming from SnmpTrapd. But the SNMPTT package cannot be found on Centos 8, is this normal?
    When I put :
    yum install snmptt
    I got : Erreur : impossible de trouver une correspondance: snmptt
    (French)
    Same problem, the net-snmp-perl package is also not found on Centos8 for the snmptrapd configuring.
    Anyone have a solution to bring me please?
    -Shahin
  • Hernandes Martins
    • Apr 2011
    • 901
    I believe you need compile
    http://www.snmptt.org/downloads.shtml
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • Shahin
      • Jun 2020
      Thank for the reply,
      I did this but when I start the service snmptt I get :
      Starting snmptt: Can't locate Text/Balanced.pm in @INC (you may need to install the Text::Balanced module) (@INC cintains: /usr/local/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5) at /usr/sbin/snmptt line 311
      I downloaded Text/Balanced.pm separately but I don't know in which directory I have to past it
      • aquablast.rus
        aquablast.rus commented
        Didn't need to download Text/Balanced.pm separately. In journalctl you were given a hint that you need to install the perl module named as Text::Balanced. That is, you should have installed perl-Text-Balanced package using dnf. And by the way, some additional perl packages installation are required too. See the details through journalctl after snmptt start.
    • rommeljimenez
      • Aug 2020
      Hello Shahin, Were you able to fix the issue? I am having the exact same problem. Thanks in advance RJ
      • Shahin
        Shahin commented
        Hi ! Yes I fixed my poblem. I followed the handled installation as suggested Hernandes in the first comment.
    • tim.mooney
      • Dec 2012
      • 1437
      It's probably worth reading through this, too: https://support.zabbix.com/browse/ZBX-17192
