How to compile Zabbix agent 2 from sources while can not connect to internet?
  • jdreal
    • Mar 2019
    • 10
    Hello , I'm trying to deploy agent 2 on SUSE11.
    I have successfully installed the Go environment.
    I excute "./configure --prefix=/zabbix --enable-agent2", it works fine.
    And then I excute "make install", an error occrus: "go: github.com/alimy/mc/[email protected]: Get https://proxy.golang.org/github.com/...@v/v2.0.3.mod: dial tcp: lookup proxy.golang.org on [::1]:53: read udp [::1]:33631->[::1]:53: read: connection refused".
    It seems that the "make install" process will download some "golang's things" from internet. But my vm(SUSE11) can not connect to internet.
    I have another vm which can connect to internet so I can download the "golang's things" and send it to vm(SUSE11).But I don't know what is needed.
    Does nybody know what will the "make install" process download ?
    Thank you very much!
  • Hernandes Martins
    • Apr 2011
    • 901
    Take a test another server to make install with internet access and compare .
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • jdreal
      • Mar 2019
      • 10
      Thank you,problem solved.
