Active check
  • GeorgeKup
    • Nov 2019
    • 98
    Active check
    Hello. Maybe someone will tell you. I can’t understand what the problem is. Created item:
    Type: Zabbix agent (active)
    Key: Mysql.Server-Status
    Information Type: Text
    Update Interval: 120s
    As a result, the following situation is observed: 120 seconds (2 minutes) pass, the myswl_server_status element goes into the "Not supported" status, and then another 10 minutes pass
    and zabbix receives data on the myswl_server_status element.
    Then the situation repeats. Those. data on the myswl_server_status element is received not after 2 minutes (as it should be), but after 12 minutes.
  • GeorgeKup
    • Nov 2019
    • 98
    The log shows that after 12 minutes the data is sent on this data element. And interestingly, if you request data with the command:
    zabbix_get -s 127.0.0.1 -k Mysql.Server-Status
    then they surrender at any given time.
