Append to User Macro
  • spo-helpdesk
    • Jun 2020
    I was curious if there is a way to append to a user macro. I am trying to see if we have 3 consecutive ping failures to trigger an alert. So I modified the built in expression. I want to be able to change it for certain devices as we have some equipment that is across a satellite link and its quite lossy.
    Problem Expression
    {Template Module ICMP Ping:icmpping[,{$ICMP_PACKET_COUNT},,,{$ICMP_TIMEOUT}].min(#{$ICMP_ATTEMPTS})}=1
    Recovery Expression
    {Template Module ICMP Ping:icmpping[,{$ICMP_PACKET_COUNT},,,{$ICMP_TIMEOUT}].max(#{$ICMP_ATTEMPTS_RECOVERY})}=0
    With the above expressions its throwing the following error.
Name:	Screenshot_2020-06-19 South Pole Station Configuration of triggers.png
    I would like to use the user macro so users do not have to add the # inside the user macro. Makes it a little more friendly to configure without having to remind the next admins to add #.
    Is this possible?
    Thank you,
    South Pole Helpdesk
  • spo-helpdesk
    • Jun 2020
    Just a quick bump.
