monitor remote db connections
  • greedysoul
    • Jul 2014
    • 10
    Would like to monitor remote db connections count (to ORCL - 1521) from the agent side. How would I be able to do that? Basically the count is like the result from:
    netstat -a | grep 1521 | wc -l
    TIA
  • Colttt
    • Mar 2009
    • 878
    you can create a UserParameter
    Debian-User
    Sorry for my bad english
    • greedysoul
      • Jul 2014
      • 10
      OK, yes, I found another thread which describes this. Thanks!
