Log monitor time format?
  • alj
    • Aug 2006
    • 188
    What is the format of "Log time format" of log monitor? Is it "date" +format kind of format or?
  • alj
    • Aug 2006
    • 188
    BUMP - still need help with this :-( The timestamp from the log i'm using is not being recognised by zabbix, i need some info how to use log monitor time format field.
    • Antras
      • Oct 2007
      • 12
      Did you found answer for your question? I've the same question
      • alj
        • Aug 2006
        • 188
        Nope ________
        • Niels
          • May 2007
          • 239
          I think the relevant code is the function calc_timestamp in zabbix_server/functions.c
          switch ((char) format[i]) {
          	case 'h':
          		hh=10*hh+num;
          		hhc++;
          		break;
          	case 'm':
          		mm=10*mm+num;
          		mmc++;
          		break;
          	case 's':
          		ss=10*ss+num;
          		ssc++;
          		break;
          	case 'y':
          		yyyy=10*yyyy+num;
          		yyyyc++;
          		break;
          	case 'd':
          		dd=10*dd+num;
          		ddc++;
          		break;
          	case 'M':
          		MM=10*MM+num;
          		MMc++;
          		break;
          In other words: the format is a string of h, m, s, y, d and M.
