i got this error after adding oracle template i go in discovery roles
"" Cannot connect to ODBC DSN: [SQL_ERROR]:[01000][0][[unixODBC][Driver Manager]Can't open lib '/u01/app/oracle/product/19.0.0/client_1/lib/libsqora.so.19.1' : file not found] ""
I added the Oracle Environment variable to all users on zabbix server ( ORACLE_HOME , PATH , TNS_ADMIN , LD_LIBRARY_PATH )
i can access any DB using sqlplus or isql , but still getting error in zabbix portal for any check run on DB instance ,
can you please advice ?
