Hi everyone,
I have installed Zabbix recently on Ubuntu 18.04.1 from source using installation from source documentation. I am only monitoring two hosts - including Zabbix. Since yesterday, I started to get a notification sdx: Disk read/write request responses are too high (read > 20 ms for 15m or write > 20 ms for 15m) and after searching, I found an article Optimizing MySQL for Zabbix. But, I am still getting the same problem. MySQL innodb configuration as following:
| innodb_adaptive_flushing | ON |
| innodb_adaptive_flushing_lwm | 10 |
| innodb_adaptive_hash_index | ON |
| innodb_adaptive_hash_index_parts | 8 |
| innodb_adaptive_max_sleep_delay | 150000 |
| innodb_api_bk_commit_interval | 5 |
| innodb_api_disable_rowlock | OFF |
| innodb_api_enable_binlog | OFF |
| innodb_api_enable_mdl | OFF |
| innodb_api_trx_level | 0 |
| innodb_autoextend_increment | 64 |
| innodb_autoinc_lock_mode | 1 |
| innodb_buffer_pool_chunk_size | 134217728 |
| innodb_buffer_pool_dump_at_shutdown | ON |
| innodb_buffer_pool_dump_now | OFF |
| innodb_buffer_pool_dump_pct | 25 |
| innodb_buffer_pool_filename | ib_buffer_pool |
| innodb_buffer_pool_instances | 8 |
| innodb_buffer_pool_load_abort | OFF |
| innodb_buffer_pool_load_at_startup | ON |
| innodb_buffer_pool_load_now | OFF |
| innodb_buffer_pool_size | 6442450944 |
| innodb_change_buffer_max_size | 25 |
| innodb_change_buffering | all |
| innodb_checksum_algorithm | crc32 |
| innodb_checksums | ON |
| innodb_cmp_per_index_enabled | OFF |
| innodb_commit_concurrency | 0 |
| innodb_compression_failure_threshold_pct | 5 |
| innodb_compression_level | 6 |
| innodb_compression_pad_pct_max | 50 |
| innodb_concurrency_tickets | 5000 |
| innodb_data_file_path | ibdata1:12M:autoextend |
| innodb_data_home_dir | |
| innodb_deadlock_detect | ON |
| innodb_default_row_format | dynamic |
| innodb_disable_sort_file_cache | OFF |
| innodb_doublewrite | ON |
| innodb_fast_shutdown | 1 |
| innodb_file_format | Barracuda |
| innodb_file_format_check | ON |
| innodb_file_format_max | Barracuda |
| innodb_file_per_table | ON |
| innodb_fill_factor | 100 |
| innodb_flush_log_at_timeout | 1 |
| innodb_flush_log_at_trx_commit | 0 |
| innodb_flush_method | O_DIRECT |
| innodb_flush_neighbors | 1 |
| innodb_flush_sync | ON |
| innodb_flushing_avg_loops | 30 |
| innodb_force_load_corrupted | OFF |
| innodb_force_recovery | 0 |
| innodb_ft_aux_table | |
| innodb_ft_cache_size | 8000000 |
| innodb_ft_enable_diag_print | OFF |
| innodb_ft_enable_stopword | ON |
| innodb_ft_max_token_size | 84 |
| innodb_ft_min_token_size | 3 |
| innodb_ft_num_word_optimize | 2000 |
| innodb_ft_result_cache_limit | 2000000000 |
| innodb_ft_server_stopword_table | |
| innodb_ft_sort_pll_degree | 2 |
| innodb_ft_total_cache_size | 640000000 |
| innodb_ft_user_stopword_table | |
| innodb_io_capacity | 200 |
| innodb_io_capacity_max | 2000 |
| innodb_large_prefix | ON |
| innodb_lock_wait_timeout | 50 |
| innodb_locks_unsafe_for_binlog | OFF |
| innodb_log_buffer_size | 16777216 |
| innodb_log_checksums | ON |
| innodb_log_compressed_pages | ON |
| innodb_log_file_size | 50331648 |
| innodb_log_files_in_group | 2 |
| innodb_log_group_home_dir | ./ |
| innodb_log_write_ahead_size | 8192 |
| innodb_lru_scan_depth | 1024 |
| innodb_max_dirty_pages_pct | 75 |
| innodb_max_dirty_pages_pct_lwm | 0 |
| innodb_max_purge_lag | 0 |
| innodb_max_purge_lag_delay | 0 |
| innodb_max_undo_log_size | 1073741824 |
| innodb_monitor_disable | |
| innodb_monitor_enable | |
| innodb_monitor_reset | |
| innodb_monitor_reset_all | |
| innodb_numa_interleave | OFF |
| innodb_old_blocks_pct | 37 |
| innodb_old_blocks_time | 1000 |
| innodb_online_alter_log_max_size | 134217728 |
| innodb_open_files | 2000 |
| innodb_optimize_fulltext_only | OFF |
| innodb_page_cleaners | 4 |
| innodb_page_size | 16384 |
| innodb_print_all_deadlocks | OFF |
| innodb_purge_batch_size | 300 |
| innodb_purge_rseg_truncate_frequency | 128 |
| innodb_purge_threads | 4 |
| innodb_random_read_ahead | OFF |
| innodb_read_ahead_threshold | 56 |
| innodb_read_io_threads | 8 |
| innodb_read_only | OFF |
| innodb_replication_delay | 0 |
| innodb_rollback_on_timeout | OFF |
| innodb_rollback_segments | 128 |
| innodb_sort_buffer_size | 1048576 |
| innodb_spin_wait_delay | 6 |
| innodb_stats_auto_recalc | ON |
| innodb_stats_include_delete_marked | OFF |
| innodb_stats_method | nulls_equal |
| innodb_stats_on_metadata | OFF |
| innodb_stats_persistent | ON |
| innodb_stats_persistent_sample_pages | 20 |
| innodb_stats_sample_pages | 8 |
| innodb_stats_transient_sample_pages | 8 |
| innodb_status_output | OFF |
| innodb_status_output_locks | OFF |
| innodb_strict_mode | ON |
| innodb_support_xa | ON |
| innodb_sync_array_size | 1 |
| innodb_sync_spin_loops | 30 |
| innodb_table_locks | ON |
| innodb_temp_data_file_path | ibtmp1:12M:autoextend |
| innodb_thread_concurrency | 0 |
| innodb_thread_sleep_delay | 10000 |
| innodb_tmpdir | |
| innodb_undo_directory | ./ |
| innodb_undo_log_truncate | OFF |
| innodb_undo_logs | 128 |
| innodb_undo_tablespaces | 0 |
| innodb_use_native_aio | ON |
| innodb_version | 5.7.30 |
| innodb_write_io_threads | 8 |
