Creating maps requires write access on hosts ?
  • Buzz
    • Aug 2007
    • 17
    I'm playing with maps, and I discovered that, to be able to add a host or a host group on my map, I need to have read-write access on this host / host group.
    Am I right or is it just a problem on my Zabbix config ?
    And if I'm right, then why is it so ? I thought that Read-only access would have been sufficient.... IMHO, Maps are just a view of systems' current status, and you shouldn't need write access to a server to be able to add it to a map... right ?
    Any explanation would be very welcome...
    Regards,
    Michel.
  • ingus.vilnis
    • Mar 2014
    • 908
    Hi Michel,
    The very short answer is that there is no problem in your particular Zabbix config. This is how Zabbix maps work for now.
    Best Regards,
    Ingus
    • Buzz
      • Aug 2007
      • 17
      Hi Ingus,
      thanks for your answer.
      It's not a big annoyance, I'll cope with it.
      But it would be nice if it could be modified in some future version...
      Kind regards,
      Michel.
      • BDiE8VNy
        • Apr 2010
        • 680
        See ZBXNEXT-2682
        • Buzz
          • Aug 2007
          • 17
          Cool !!!
          Many thanks !!
