Hello Folks,
I'm trying to create a zabbix aggregate item to mesure the use of incoming and outgoing Active Directory replication.
Actually, i can extract this data using the perf_counter in the following ways:
But now, I want to see a value corresponding to a group of Active Directory Servers; so, I Tried to use grpsum as the following:
Actually, i tried the other 3 ways to put the perf_counter, but I always got the same error on the server log:
Is there any way to use perf_counter on zabbix aggregate items?
Thanks in advance.
PS: My other grpsum items that uses vm.memory, etc are working normally.
HTML Code:
perf_counter[\NTDS\DRA Inbound Bytes Total/sec, 300] (Simple way) or perf_counter["\NTDS\DRA Inbound Bytes Total/sec", 300] (Quoted) or perf_counter[\"\NTDS\DRA Inbound Bytes Total/sec\", 300] (Quoted + skip) or perf_counter[\"\\NTDS\\DRA Inbound Bytes Total/sec\", 300] (Fully quotted and skipped)
HTML Code:
grpsum["DF_AD_2008","perf_counter[\"\\DirectoryServices(NTDS)\\DRA Inbound Bytes Total/sec\", 300]","last","0"]
HTML Code:
No items for key [perf_counter["\\DirectoryServices(NTDS)\\DRA Inbound Bytes Total/sec", 300]] in group(s) [DF_AD_2008]
Thanks in advance.
