Hi Forum
I have an issue after upgrading my Proxy on Pfsense -
It seems like I missing this command on my Pfsense installation:
I did find the schema.sql in ]/usr/local/share/zabbix5/proxy/database/sqlite3 - and after running the command -. I can now see the zabbix.db
But still no logs or anything while trying to start the Zabbix Proxy!
It'll look its OK - when showing Package information
WSo not sure where to look from here - for getting the service Zabbix-Proxy up and running . - It haven't been an issue with the earlier version - so please advise on how to fix this issue
sqlite3 /var/db/zabbix-proxy/zabbix.db < schema.sql
zabbix5-proxy-5.0.1 Name : zabbix5-proxy Version : 5.0.1 Installed on : Sun Jun 28 07:38:56 2020 CEST Origin : net-mgmt/zabbix5-proxy Architecture : FreeBSD:11:amd64 Prefix : /usr/local Categories : net-mgmt Licenses : GPLv2+ Maintainer : [email protected] WWW : https://www.zabbix.com/ Comment : Enterprise-class open source distributed monitoring (proxy) LTS Options : CURL : on FPING : on GNUTLS : off IPMI : on IPV6 : on LDAP : off LIBXML2 : on MYSQL : off NMAP : off OPENSSL : on ORACLE : off PGSQL : off SQLITE : on SSH : on UNIXODBC : on Shared Libs required: libcurl.so.4 libpcre.so.1 libodbc.so.2 libevent-2.1.so.7 libnetsnmp.so.30 libsqlite3.so.0 libOpenIPMIposix.so.0 libOpenIPMI.so.0 libssh2.so.1 libxml2.so.2 Annotations : FreeBSD_version: 1103507 repo_type : binary repository : pfSense Flat size : 35.7MiB
