SQL query returns inconsistent disabled items amount
  • marcioale
    • Sep 2019
    • 14
    Hi guys,
    I´m trying to generate report of all disable items on Zabbix database with the following query:
    select a1.host, a2.itemid,a2.name from hosts a1, items a2
    where a1.hostid = a2.hostid
    and a2.status = 1;
    When I run this query I got 183 disabled items but the system information widget tells me that I have 201 disabled items
    Do you know why the amount does not match? Is my sql query right?
    Thanks,
  • Hamardaban
    • May 2019
    • 2714
    The number of unsupported items is calculated from information in the cache, not in the database. To get a list of unsupported items, you can use a filter on the data item form.
    • marcioale
      marcioale commented
      Hi Hamardaban,
      I Know that we can  get a list of unsupported/disabled items from data item form but the point is, we cannot export this report to work on this data afterwards.
      So that´s why I´ve been trying to retrieve a report from Zabbix database.
      The following query is not wront at all.
      and a2.status = 1;
      For example, when I change a item status on Zabbix its status also change on querys result and what I need to know is why the result of the query does not match with the system information widget.
      Is some "inner join" with another table missing? Or is there another way to generate a report of disabled items on Zabbix, like using command line.
      Thanks,
  • marcioale
    • Sep 2019
    • 14
    Hi Hamardaban,
    and a2.status = 1;
    Thanks,
    • Hamardaban
      • May 2019
      • 2714
      What version of zabbix do you use?
      Try counting the number of deactivated data items without binding them to hosts.
      But once again, data for the GUI is taken from the cache, not from the database. How they get there, how they are counted, and how they are synchronized with the database is not an easy question. You can try looking in the source codes. You may find the following information about key values in tables useful (for version 4.4)
      Host
      status:
      0, HOST_STATUS_MONITORED - Host is monitored
      1, HOST_STATUS_NOT_MONITORED - Host is not monitored
      3, HOST_STATUS_TEMPLATE - The record is template
      5, HOST_STATUS_PROXY_ACTIVE - The record is active proxy
      6, HOST_STATUS_PROXY_PASSIVE - The record is passive proxy
      flags:
      0x00, ZBX_FLAG_DISCOVERY_NORMAL - Normal host
      0x02, ZBX_FLAG_DISCOVERY_PROTOTYPE - Host prototype
      0x04, ZBX_FLAG_DISCOVERY_CREATED - Auto-created host
      Items
      type integer Type of the item or LLD rule:
      0, ITEM_TYPE_ZABBIX - Zabbix agent
      1, ITEM_TYPE_SNMPV1 - SNMPv1 agent
      2, ITEM_TYPE_TRAPPER - Zabbix trapper
      3, ITEM_TYPE_SIMPLE - Simple check
      4, ITEM_TYPE_SNMPV2C - SNMPv2 agent
      5, ITEM_TYPE_INTERNAL - Zabbix internal
      6, ITEM_TYPE_SNMPV3 - SNMPv3 agent
      7, ITEM_TYPE_ZABBIX_ACTIVE - Zabbix agent (active) check
      8, ITEM_TYPE_AGGREGATE - Aggregate
      9, ITEM_TYPE_HTTPTEST - HTTP test (web monitoring scenario step)
      10, ITEM_TYPE_EXTERNAL - External check
      11, ITEM_TYPE_DB_MONITOR - Database monitor
      12, ITEM_TYPE_IPMI - IPMI agent
      13, ITEM_TYPE_SSH - SSH agent
      14, ITEM_TYPE_TELNET - TELNET agent
      15, ITEM_TYPE_CALCULATED - Calculated
      16, ITEM_TYPE_JMX - JMX agent
      17, ITEM_TYPE_SNMPTRAP - SNMP trap
      18, ITEM_TYPE_DEPENDENT - Dependent item
      19, ITEM_TYPE_HTTPAGENT - HTTP agent
      status integer Status of the item:
      0, ITEM_STATUS_ACTIVE - Active
      1, ITEM_STATUS_DISABLED - Disabled
