monitoring process only if run with specific arguments
  • ilia
    • Dec 2018
    • 37
    i am trying to monitor process only if it running with specific set of arguments that passed to him, is it possible?
    currently i am monitoring using proc.num[ProcesssName]
  • ilia
    • Dec 2018
    • 37
    anyone got an idea how to do it?
    • gert.derouck
      • Jan 2020
      • 69
      Hi Ilia,
      on which OS you want to check for this specific process?
      You can use some user parameter?
      Some thing like:
      UserParameter=os.process[*],ps -ef |grep '$1'
      Regards
      Gert
      • ilia
        • Dec 2018
        • 37
        Originally posted by gert.derouck
        Hi Ilia,
        Gert
        Centos 7
        Hi Ilia,
        Some thing like:
        Gert
        how does it help?
        i have a process, if it run like this run -A i want to monitor it and trigger upon crash
        and if it run with another argument like run -B i dont want to monitor it
        • Hamardaban
          • May 2019
          • 2714
          What does "monitoring the process" mean to you?
          • tim.mooney
            • Dec 2012
            • 1436
            Are you saying that the 4th argument to proc.num[] doesn't do what you need?
            proc.num[<name>,<user>,<state>,<cmdline>,<zone>]
            • ilia
              • Dec 2018
              • 37
              i am trying to signal a notification only when the process that started with specific argument crashed. or return to normal state after crash
              i didnt know about it,
              ​​​​​​​ill give it a try
              • ilia
                • Dec 2018
                • 37
                it worked, thanks
