Regular Expression Problem
  • braghiatto@hotmail.com
    • Jun 2020
    Can you help me? Until version 4.4 using regular expression, it was possible to block the discovery of pppoe connections. However, now in version 5, regular expression does not work ... Even with the rule giving FALSE on everything containing pppoe, the discovery continues to seek information from pppoe connections. I believe it is a bug in the new version. Has anyone found a solution?
    • Jun 2020
    Any can help??
    • incama
      • Jan 2015
      • 67
      Could you try ^pppoe ?
        [email protected] commented
        Yes. Not working.
        In new version not run expression regular for deny discovery interface pppoe.
        Needing, edit the template for solve it.
