Zabbix Dashboard and Graph show only on same subnet with zabbix server
  • toyotaro83
    • Jul 2020
    I have zabbix 4.4.5 server on Ubuntu 18 and many vm,appliance,and network device to monitor. I dont know if this strange or not, but when im in different subnet with zabbix server(192.168.1.0/24) my dashboard/graph dont show anything, but i can see host last data. If i in the same subnet with zabbix , i can see the dashboard and graph. Is there some config i miss, i already check the network firewall and i dont see any logs.
    --EDit, i know the reason
  • Hamardaban
    • May 2019
    • 2714
    Perhaps this phenomenon is related to the web server settings, in particular with the content security policy. look in the browser error console - there may be messages about blocking certain content.
    • tim.mooney
      • Dec 2012
      • 1436
      It might be helpful to someone else in the future if you follow up with information on what the problem was and what you did to fix it.
      • toyotaro83
        • Jul 2020
        Mr Hamardaban is right, i only look on the network firewall log, which strangely i cant find any log related. Then i using browser developer tool like inspect tool to find which element got 4xx or 5xx. And them i see a jsLoader file cant get loaded said about incorect text/html nosniff, first i think is apache seting or folder setting, i edit apache and zabbix php file its not work, this is where i blank.
        And then i look again at firewall rule, and i see a waf rule and i disable it. And it works, i can see the dashboard now.
        Im pretty sure i already check all firewall log which i cant find aany related log to zabbix server.
