Zabbix API and Graphs
  • bcsx123
    • Sep 2014
    • 14
    Hi.
    Is it possible using API to get a graph with a specific id, pass to the request a time interval and print the graph in my page, for example as an image?
    I have read the documentation and I am not sure if this can be done using API.
    Thank you.
  • authex
    • Jan 2014
    • 32
    Hi there bcsx123,
    I currently use StatusBoard (iPad connected to Television) and I am able to display graphs in real time. I'm not sure if this is something you would consider, but this leads me to believe that API's are meant to work like you want them to.
    Hope this helps
    • aib
      • Jan 2014
      • 1615
      Check https://www.zabbix.com/forum/showthread.php?t=30267
      May be you can use for your page the graph, created by zabbix server?
      http://zabbix_url/chart2.php?graphid=1234
      Sincerely yours,
      Aleksey
      • bcsx123
        • Sep 2014
        • 14
        Hi.
        I have already seen this thread. I like the idea but the problem is that I need to change the time interval for the graph. Do you know if is possible to pass a time inteval through the URL?
        Thanks.
        • aib
          • Jan 2014
          • 1615
          Yes, you can.
          As it described in that thread
          Use additional GET parameters:
              width=[width in px]
              height=[height in px]
              period=[period in seconds]
              stime=[start timestamp]
          Sincerely yours,
          Aleksey
          • bcsx123
            • Sep 2014
            • 14
            Yes, you can.
                width=[width in px]
            How could I have missed these parameters? Thank you very much!
            • Sevier
              • Oct 2017
              Originally posted by bcsx123
              How could I have missed these amazing Phallosan Forte results and parameters? Thank you very much!
              The paramaters don't do anything for me.
