All of my snmp traps are unknown - Centos 8
  • Shahin
    • Jun 2020
    Hi ! I try to received snmp traps on my zabbix server. I use SNMPTT service instead of the perl script (not existing in Centos8).
    I can see almost all of the SNMP chain :
    I can see the trap arrived on my 161 port, Snmptrapd takes my traps and, via snmptthandle, put it in the repertory : /var/spool/snmptt
    After, SNMPTT deamon put the trap and after NOTHING ! I can see my trap in /var/log/snmptt/snmpttunknown.log it means that my trap is considered "UNKNOWN" and I don't know how I can resolve this issue.
    I'd want to see my traps arrived in /tmp/zabbix_traps.tmp in order to be handled by Zabbix.
    However I translated my Mib file via snmpttconvertmib...
    Please, anyone could help me please ? Thanks!!
    my config files :
    /ect/snmp/snmptrapd.conf
    # Example configuration file for snmptrapd
    # No traps are handled by default, you must edit this file!
    #snmpTrapdAddr 127.0.0.1:162
    #snmpTrapdAddr 172.28.28.251:162
    authCommunity log,execute,net public
    traphandle default /usr/sbin/snmptthandler --ini=/etc/snmp/snmptt.ini --debug=1 --debugfile=/var/log/snmptt/debugOutput.log
    #perl do "/root/snmptt_1.4/snmptthandler-embedded";
    #traphandle default /usr/sbin/snmptt
    disableAuthorization yes
    forward default unix:/var/spool/snmptt
    doNotRetainNotificationLogs yes
    #doNotLogTraps yes
    doNotFork yes
    pidFile /var/spool/snmptt/snmptt.txt
    /etc/snmp/snmptt.conf
    EVENT general .* "General event" Normal
    FORMAT ZBXTRAP $aA $ar
    # SNMPTT v1.4 Configuration File
    # Linux / Unix
    [General]
    # Name of this system for $H variable. If blank, system name will be the computer's
    # hostname via Sys::Hostname.
    snmptt_system_name = snmptt
    # Set to either 'standalone' or 'daemon'
    # standalone: snmptt called from snmptrapd.conf
    # daemon: snmptrapd.conf calls snmptthandler
    # Ignored by Windows. See documentation
    #mode = standalone
    mode = daemon
    # Set to 1 to allow multiple trap definitions to be executed for the same trap.
    # Set to 0 to have it stop after the first match.
    # This option should normally be set to 1. See the section 'SNMPTT.CONF Configuration
    # file Notes' in the SNMPTT documentation for more information.
    # Note: Wildcard matches are only matched if there are NO exact matches. This takes
    # into consideration the NODES list. Therefore, if there is a matching trap, but
    # the NODES list prevents it from being considered a match, the wildcard entry will
    # only be used if there are no other exact matches.
    multiple_event = 1
    # SNMPTRAPD passes the IP address of device sending the trap, and the IP address of the
    # actual SNMP agent. These addresses could differ if the trap was sent on behalf of another
    # device (relay, proxy etc).
    # If DNS is enabled, the agent IP address is converted to a host name using a DNS lookup
    # (which includes the local hosts file, depending on how the OS is configured). This name
    # will be used for: NODES entry matches, hostname field in logged traps (file / database),
    # and the $A variable. Host names on the NODES line will be resolved and the IP address
    # will then be used for comparing.
    # Set to 0 to disable DNS resolution
    # Set to 1 to enable DNS resolution
    dns_enable = 0
    # Set to 0 to enable the use of FQDN (Fully Qualified Domain Names). If a host name is
    # passed to SNMPTT that contains a domain name, it will not be altered in any way by
    # SNMPTT. This also affects resolve_value_ip_addresses.
    # Set to 1 to have SNMPTT strip the domain name from the host name passed to it. For
    # example, server01.domain.com would be changed to server01
    # Set to 2 to have SNMPTT strip the domain name from the host name passed to it
    # based on the list of domains in strip_domain_list
    strip_domain = 0
    # List of domain names that should be stripped when strip_domain is set to 2.
    # List can contain one or more domains. For example, if the FQDN of a host is
    # server01.city.domain.com and the list contains domain.com, the 'host' will be
    # set as server01.city.
    strip_domain_list = <<END
    domain.com
    END
    # Configures how IP addresses contained in the VALUE of the variable bindings are handled.
    # This only applies to the values for $n, $+n, $-n, $vn, $+*, $-*.
    # Set to 0 to disable resolving ip address to host names
    # Set to 1 to enable resolving ip address to host names
    # Note: net_snmp_perl_enable *must* be enabled. The strip_domain settings influence the
    # format of the resolved host name. DNS must be enabled (dns_enable)
    resolve_value_ip_addresses = 0
    # Set to 1 to enable the use of the Perl module from the UCD-SNMP / NET-SNMP package.
    # This is required for $v variable substitution to work, and also for some other options
    # that are enabled in this .ini file.
    # Set to 0 to disable the use of the Perl module from the UCD-SNMP / NET-SNMP package.
    # Note: Enabling this with stand-alone mode can cause SNMPTT to run very slowly due to
    # the loading of the MIBS at startup.
    net_snmp_perl_enable = 0
    # Set to 1 to enable caching of OID and ENUM translations when net_snmp_perl_enable is
    # enabled. Enabling this should result in faster translations.
    # Set to 0 to disable caching.
    # Note: Restart SNMPTT after updating the MIB files for Net-SNMP, otherwise the cache may
    # contain inaccurate data. Defaults to 1.
    net_snmp_perl_cache_enable = 0
    # This sets the best_guess parameter used by the UCD-SNMP / NET-SNMP Perl module for
    # translating symbolic nams to OIDs and vice versa.
    # For UCD-SNMP, and Net-SNMP 5.0.8 and previous versions, set this value to 0.
    # For Net-SNMP 5.0.9, or any Net-SNMP with patch 722075 applied, set this value to 2.
    # A value of 2 is equivalent to -IR on Net-SNMP command line utilities.
    # UCD-SNMP and Net-SNMP 5.0.8 and previous may not be able to translate certain formats of
    # symbolic names such as RFC1213-MIB::sysDescr. Net-SNMP 5.0.9 or patch 722075 will allow
    # all possibilities to be translated. See the FAQ section in the README for more info
    net_snmp_perl_best_guess = 0
    # Configures how the OID of the received trap is handled when outputting to a log file /
    # database. It does NOT apply to the $O variable.
    # Set to 0 to use the default of numerical OID
    # Set to 1 to translate the trap OID to short text (symbolic form) (eg: linkUp)
    # Set to 2 to translate the trap OID to short text with module name (eg: IF-MIB::linkUp)
    # Set to 3 to translate the trap OID to long text (eg: iso...snmpTraps.linkUp)
    # Set to 4 to translate the trap OID to long text with module name (eg:
    # IF-MIB::iso...snmpTraps.linkUp)
    # Note: -The output of the long format will vary depending on the version of Net-SNMP you
    # are using.
    # -net_snmp_perl_enable *must* be enabled
    # -If using database logging, ensure the trapoid column is large enough to hold the
    # entire line
    translate_log_trap_oid = 1
    # Configures how OIDs contained in the VALUE of the variable bindings are handled.
    # This only applies to the values for $n, $+n, $-n, $vn, $+*, $-*. For substitutions
    # that include variable NAMES ($+n etc), only the variable VALUE is affected.
    # Set to 0 to disable translating OID values to text (symbolic form)
    # Set to 1 to translate OID values to short text (symbolic form) (eg: BuildingAlarm)
    # Set to 2 to translate OID values to short text with module name (eg: UPS-MIB::BuildingAlarm)
    # Set to 3 to translate OID values to long text (eg: iso...upsAlarm.BuildingAlarm)
    # Set to 4 to translate OID values to long text with module name (eg:
    # UPS-MIB::iso...upsAlarm.BuildingAlarm)
    # For example, if the value contained: 'A UPS Alarm (.1.3.6.1.4.1.534.1.7.12) has cleared.',
    # it could be translated to: 'A UPS Alarm (UPS-MIB::BuildingAlarm) has cleared.'
    translate_value_oids = 1
    # Configures how the symbolic enterprise OID will be displayed for $E.
    # Set to 1, 2, 3 or 4. See translate_value_oids options 1,2,3 and 4.
    translate_enterprise_oid_format = 1
    # Configures how the symbolic trap OID will be displayed for $O.
    translate_trap_oid_format = 1
    # Configures how the symbolic trap OID will be displayed for $v, $-n, $+n, $-* and $+*.
    translate_varname_oid_format = 1
    # Set to 0 to disable converting INTEGER values to enumeration tags as defined in the
    # MIB files
    # Set to 1 to enable converting INTEGER values to enumeration tags as defined in the
    # MIB files
    # Example: moverDoorState:open instead of moverDoorState:2
    translate_integers = 1
    # Allows you to set the MIBS environment variable used by SNMPTT
    # Leave blank or comment out to have the systems enviroment settings used
    # To have all MIBS processed, set to ALL
    # See the snmp.conf manual page for more info
    mibs_environment = ALL
    # Set what is used to separate variables when wildcards are expanded on the FORMAT /
    # EXEC line. Defaults to a space. Value MUST be within quotes. Can contain 1 or
    # more characters
    wildcard_expansion_separator = " "
    # Set to 1 to allow unsafe REGEX code to be executed.
    # Set to 0 to prevent unsafe REGEX code from being executed (default).
    # Enabling unsafe REGEX code will allow variable interopolation and the use of the e
    # modifier to allow statements such as substitution with captures such
    # as: (one (two) three)(five $1 six)
    # which outputs: five two six
    # or: (one (two) three)("five ".length($1)." six")e
    # which outputs: five 3 six
    # This is considered unsafe because the contents of the regular expression
    # (right) is executed (eval) by Perl which *could contain unsafe code*.
    # BE SURE THAT THE SNMPTT CONFIGURATION FILES ARE SECURE!
    allow_unsafe_regex = 0
    # Set to 1 to have the backslash (escape) removed from quotes passed from
    # snmptrapd. For example, \" would be changed to just "
    remove_backslash_from_quotes = 0
    # Set to 1 to have NODES files loaded each time a trap is processed.
    # Set to 0 to have all NODES files loaded when the snmptt.conf files are loaded.
    # If NODES files are used (files that contain lists of NODES), then setting to 1
    # will cause the list to be loaded each time an EVENT is processed that uses
    # NODES files. This will allow the NODES file to be modified while SNMPTT is
    # running but can result in many file reads depending on the number of traps
    # received. Defaults to 0
    dynamic_nodes = 0
    # This option allows you to use the $D substitution variable to include the
    # description text from the SNMPTT.CONF or MIB files.
    # Set to 0 to disable the $D substitution variable. If $D is used, nothing
    # will be outputted.
    # Set to 1 to enable the $D substitution variable and have it use the
    # descriptions stored in the SNMPTT .conf files. Enabling this option can
    # greatly increase the amount of memory used by SNMPTT.
    # Set to 2 to enable the $D substitution variable and have it use the
    # description from the MIB files. This enables the UCD-SNMP / NET-SNMP Perl
    # module save_descriptions variable. Enabling this option can greatly
    # increase the amount of memory used by the Net-SNMP SNMP Perl module, which
    # will result in an increase of memory usage by SNMPTT.
    description_mode = 0
    # Set to 1 to remove any white space at the start of each line from the MIB
    # or SNMPTT.CONF description when description_mode is set to 1 or 2.
    description_clean = 1
    # Warning: Experimental. Not recommended for production environments.
    # When threads are enabled, SNMPTT may quit unexpectedly.
    # Set to 1 to enable threads (ithreads) in Perl 5.6.0 or higher. If enabled,
    # EXEC will launch in a thread to allow SNMPTT to continue processing other
    # traps. See also threads_max.
    # Set to 0 to disable threads (ithreads).
    # Defaults to 0
    threads_enable = 0
    # This option allows you to set the maximum number of threads that will
    # execute at once. Defaults to 10
    threads_max = 10
    # The date format for $x in strftime() format. If not defined, defaults
    # to %a %b %e %Y.
    #date_format = %a %b %e %Y
    # The time format for $X in strftime() format. If not defined, defaults
    # to %H:%M:%S.
    #time_format = %H:%M:%S
    # The date time format in strftime() format for the date/time when logging
    # to standard output, snmptt log files (log_file) and the unknown log file
    # (unknown_trap_log_file). Defaults to localtime(). For SQL, see
    # date_time_format_sql.
    # Example: %a %b %e %Y %H:%M:%S
    date_time_format = %H:%M:%S %Y/%m/%d
    [DaemonMode]
    # Set to 1 to have snmptt fork to the background when run in daemon mode
    daemon_fork = 1
    # Set to the numerical user id (eg: 500) or textual user id (eg: snmptt)
    # that snmptt should change to when running in daemon mode. Leave blank
    # to disable. The user used should have read/write access to all log
    # files, the spool folder, and read access to the configuration files.
    # Only use this if you are starting snmptt as root.
    # A second (child) process will be started as the daemon_uid user so
    # there will be two snmptt processes running. The first process will
    # continue to run as the user that ran snmptt (root), waiting for the
    # child to quit. After the child quits, the parent process will remove
    # the snmptt.pid file and exit.
    daemon_uid = snmptt
    # Complete path of file to store process ID when running in daemon mode.
    pid_file = /var/run/snmptt.pid
    # Directory to read received traps from. Ex: /var/spool/snmptt/
    # Don't forget the trailing slash!
    spool_directory = /var/spool/snmptt/
    # Amount of time in seconds to sleep between processing spool files
    sleep = 5
    # Set to 1 to have SNMPTT use the time that the trap was processed by SNMPTTHANDLER
    # Set to 0 to have SNMPTT use the time the trap was processed. Note: Using 0 can
    # result in the time being off by the number of seconds used for 'sleep'
    use_trap_time = 1
    # Set to 0 to have SNMPTT erase the spooled trap file after it attempts to process
    # the trap even if it did not successfully log the trap to any of the log systems.
    # Set to 1 to have SNMPTT erase the spooled trap file only after it successfully
    # logs to at least ONE log system.
    # Set to 2 to have SNMPTT erase the spooled trap file only after it successfully
    # logs to ALL of the enabled log systems. Warning: If multiple log systems are
    # enabled and only one fails, the other log system will continuously be logged to
    # until ALL of the log systems function.
    # The recommended setting is 1 with only one log system enabled.
    keep_unlogged_traps = 1
    # How often duplicate traps will be processed. An MD5 hash of all incoming traps
    # is stored in memory and is used to check for duplicates. All variables except for
    # the uptime variable are used when calculating the MD5. The larger this variable,
    # the more memory snmptt will require.
    # Note: In most cases it may be a good idea to enable this but sometimes it can have a
    # negative effect. For example, if you are trying to troubleshoot a wireless device
    # that keeps losing it's connection you may want to disable this so that you see
    # all the associations and disassociations.
    # 5 minutes = 300
    # 10 minutes = 600
    # 15 minutes = 900
    duplicate_trap_window = 0
    [Logging]
    # Set to 1 to enable messages to be sent to standard output, or 0 to disable.
    # Would normally be disabled unless you are piping this program to another
    stdout_enable = 0
    # Set to 1 to enable text logging of *TRAPS*. Make sure you specify a log_file
    # location
    log_enable = 1
    # Log file location. The COMPLETE path and filename. Ex: '/var/log/snmptt/snmptt.log'
    #log_file = /var/log/snmptt/snmptt.log
    log_file = /tmp/zabbix_traps.tmp
    # Set to 1 to enable text logging of *SNMPTT system errors*. Make sure you
    # specify a log_system_file location
    log_system_enable = 1
    # Ex: '/var/log/snmptt/snmpttsystem.log'
    log_system_file = /var/log/snmptt/snmpttsystem.log
    # Set to 1 to enable logging of unknown traps. This should normally be left off
    # as the file could grow large quickly. Used primarily for troubleshooting. If
    # you have defined a trap in snmptt.conf, but it is not executing, enable this to
    # see if it is being considered an unknown trap due to an incorrect entry or
    # simply missing from the snmptt.conf file.
    # Unknown traps can be logged either a text file, a SQL table or both.
    # See SQL section to define a SQL table to log unknown traps to.
    unknown_trap_log_enable = 1
    # Unknown trap log file location. The COMPLETE path and filename.
    # Ex: '/var/log/snmptt/snmpttunknown.log'
    # Leave blank to disable logging to text file if logging to SQL is enabled
    # for unknown traps
    unknown_trap_log_file = /var/log/snmptt/snmpttunknown.log
    # How often in seconds statistics should be logged to syslog or the event log.
    # 1 hour = 216000
    # 12 hours = 2592000
    # 24 hours = 5184000
    statistics_interval = 0
    # Set to 1 to enable logging of *TRAPS* to syslog. If you do not have the Sys::Syslog
    # module then disable this. Windows users should disable this.
    syslog_enable = 1
    # Syslog facility to use for logging of *TRAPS*. For example: 'local0'
    syslog_facility = local0
    # Set the syslog level for *TRAPS* based on the severity level of the trap
    # as defined in the snmptt.conf file. Values must be one per line between
    # the syslog_level_* and END lines, and are not case sensitive. For example:
    # Warning
    # Critical
    # Duplicate definitions will use the definition with the higher severity.
    syslog_level_debug = <<END
    END
    syslog_level_info = <<END
    END
    syslog_level_notice = <<END
    END
    syslog_level_warning = <<END
    END
    syslog_level_err = <<END
    END
    syslog_level_crit = <<END
    END
    syslog_level_alert = <<END
    END
    # Syslog default level to use for logging of *TRAPS*. For example: warning
    # Valid values: emerg, alert, crit, err, warning, notice, info, debug
    syslog_level = warning
    # Set to 1 to enable logging of *SNMPTT system errors* to syslog. If you do not have the
    # Sys::Syslog module then disable this. Windows users should disable this.
    syslog_system_enable = 1
    # Syslog facility to use for logging of *SNMPTT system errors*. For example: 'local0'
    syslog_system_facility = local0
    # Syslog level to use for logging of *SNMPTT system errors*.. For example: 'warning'
    syslog_system_level = warning
    [SQL]
    # Determines if the enterprise column contains the numeric OID or symbolic OID
    # Set to 0 for numeric OID
    # Set to 1 for symbolic OID
    # Uses translate_enterprise_oid_format to determine format
    db_translate_enterprise = 0
    # FORMAT line to use for unknown traps. If not defined, defaults to $-*.
    db_unknown_trap_format = '$-*'
    # List of custom SQL column names and values for the table of received traps
    # (defined by *_table below). The format is
    # column name
    # value
    # For example:
    # binding_count
    # uptime2
    # The agent has been up for $T.
    sql_custom_columns = <<END
    END
    # List of custom SQL column names and values for the table of unknown traps
    # (defined by *_table_unknown below). See sql_custom_columns for the format.
    sql_custom_columns_unknown = <<END
    END
    # MySQL: Set to 1 to enable logging to a MySQL database via DBI (Linux / Windows)
    # This requires DBI:: and DBD::mysql
    mysql_dbi_enable = 0
    # MySQL: Hostname of database server (optional - default localhost)
    mysql_dbi_host = localhost
    # MySQL: Port number of database server (optional - default 3306)
    mysql_dbi_port = 3306
    # MySQL: Database to use
    mysql_dbi_database = snmptt
    # MySQL: Table to use
    mysql_dbi_table = snmptt
    # MySQL: Table to use for unknown traps
    # Leave blank to disable logging of unknown traps to MySQL
    # Note: unknown_trap_log_enable must be enabled.
    mysql_dbi_table_unknown = snmptt_unknown
    # MySQL: Table to use for statistics
    # Note: statistics_interval must be set. See also stat_time_format_sql.
    #mysql_dbi_table_statistics = snmptt_statistics
    # MySQL: Username to use
    mysql_dbi_username = snmpttuser
    # MySQL: Password to use
    mysql_dbi_password = password
    # MySQL: Whether or not to 'ping' the database before attempting an INSERT
    # to ensure the connection is still valid. If *any* error is generate by
    # the ping such as 'Unable to connect to database', it will attempt to
    # re-create the database connection.
    # Note: This has no effect on mysql_ping_interval.
    mysql_ping_on_insert = 1
    # MySQL: How often in seconds the database should be 'pinged' to ensure the
    # connection is still valid. If *any* error is generate by the ping such as
    # 'Unable to connect to database', it will attempt to re-create the database
    # connection. Set to 0 to disable pinging.
    # Note: This has no effect on mysql_ping_on_insert.
    # disabled = 0
    # 5 minutes = 300
    # 15 minutes = 900
    # 30 minutes = 1800
    mysql_ping_interval = 300
    # PostgreSQL: Set to 1 to enable logging to a PostgreSQL database via DBI (Linux / Windows)
    # This requires DBI:: and DBD::PgPP
    postgresql_dbi_enable = 0
    # Set to 0 to use the DBD::PgPP module
    # Set to 1 to use the DBD::Pg module
    postgresql_dbi_module = 0
    # Set to 0 to disable host and port network support
    # Set to 1 to enable host and port network support
    # If set to 1, ensure PostgreSQL is configured to allow connections via TCPIP by setting
    # tcpip_socket = true in the $PGDATA/postgresql.conf file, and adding the ip address of
    # the SNMPTT server to $PGDATApg_hba.conf. The common location for the config files for
    # RPM installations of PostgreSQL is /var/lib/pgsql/data.
    postgresql_dbi_hostport_enable = 0
    # PostgreSQL: Hostname of database server (optional - default localhost)
    postgresql_dbi_host = localhost
    # PostgreSQL: Port number of database server (optional - default 5432)
    postgresql_dbi_port = 5432
    # PostgreSQL: Database to use
    postgresql_dbi_database = snmptt
    # PostgreSQL: Table to use for unknown traps
    # Leave blank to disable logging of unknown traps to PostgreSQL
    postgresql_dbi_table_unknown = snmptt_unknown
    # PostgreSQL: Table to use for statistics
    #postgresql_dbi_table_statistics = snmptt_statistics
    postgresql_dbi_table = snmptt
    # PostgreSQL: Username to use
    postgresql_dbi_username = snmpttuser
    # PostgreSQL: Password to use
    postgresql_dbi_password = password
    # PostgreSQL: Whether or not to 'ping' the database before attempting an INSERT
    # Note: This has no effect on postgresqll_ping_interval.
    postgresql_ping_on_insert = 1
    # PostgreSQL: How often in seconds the database should be 'pinged' to ensure the
    # Note: This has no effect on postgresql_ping_on_insert.
    # disabled = 0
    # 5 minutes = 300
    # 15 minutes = 900
    # 30 minutes = 1800
    postgresql_ping_interval = 300
    # ODBC: Set to 1 to enable logging to a database via ODBC using DBD::ODBC.
    # This requires both DBI:: and DBD::ODBC
    dbd_odbc_enable = 0
    # DBD:ODBC: Database to use
    dbd_odbc_dsn = snmptt
    # DBD:ODBC: Table to use
    dbd_odbc_table = snmptt
    # DBD:ODBC: Table to use for unknown traps
    # Leave blank to disable logging of unknown traps to DBD:ODBC
    dbd_odbc_table_unknown = snmptt_unknown
    # DBD:ODBC: Table to use for statistics
    #dbd_odbc_table_statistics = snmptt_statistics
    # DBD:ODBC: Username to use
    dbd_odbc_username = snmptt
    # DBD:DBC:: Password to use
    dbd_odbc_password = password
    # DBD:ODBC: Whether or not to 'ping' the database before attempting an INSERT
    # Note: This has no effect on dbd_odbc_ping_interval.
    dbd_odbc_ping_on_insert = 1
    # DBD:ODBC:: How often in seconds the database should be 'pinged' to ensure the
    # Note: This has no effect on dbd_odbc_ping_on_insert.
    # disabled = 0
    # 5 minutes = 300
    # 15 minutes = 900
    # 30 minutes = 1800
    dbd_odbc_ping_interval = 300
    # The date time format for the traptime column in SQL. Defaults to
    # localtime(). When a date/time field is used in SQL, this should
    # be changed to follow a standard that is supported by the SQL server.
    # Example: For a MySQL DATETIME, use %Y-%m-%d %H:%M:%S.
    #date_time_format_sql =
    # The date time format for the stat_time column in SQL. Defaults to
    #stat_time_format_sql =
    [Exec]
    # Set to 1 to allow EXEC statements to execute. Should normally be left on unless you
    # want to temporarily disable all EXEC commands
    exec_enable = 1
    # Set to 1 to allow PREEXEC statements to execute. Should normally be left on unless you
    # want to temporarily disable all PREEXEC commands
    pre_exec_enable = 1
    # If defined, the following command will be executed for ALL unknown traps. Passed to the
    # command will be all standard and enterprise variables, similar to unknown_trap_log_file
    # but without the newlines.
    unknown_trap_exec =
    # FORMAT line that is passed to the unknown_trap_exec command. If not defined, it
    # defaults to what is described in the unknown_trap_exec setting. The following
    # would be *similar* to the default described in the unknown_trap_exec setting
    # (all on one line):
    # $x !! $X: Unknown trap ($o) received from $A at: Value 0: $A Value 1: $aR
    # Value 2: $T Value 3: $o Value 4: $aA Value 5: $C Value 6: $e Ent Values: $+*
    unknown_trap_exec_format =
    # Set to 1 to escape wildards (* and ?) in EXEC, PREEXEC and the unknown_trap_exec
    # commands. Enable this to prevent the shell from expanding the wildcard
    # characters. The default is 1.
    exec_escape = 1
    [Debugging]
    # 0 - do not output messages
    # 1 - output some basic messages
    # 2 - out all messages
    DEBUGGING = 0
    # Debugging file - SNMPTT
    # Location of debugging output file. Leave blank to default to STDOUT (good for
    # standalone mode, or daemon mode without forking)
    DEBUGGING_FILE =
    # DEBUGGING_FILE = /var/log/snmptt/snmptt.debug
    # Debugging file - SNMPTTHANDLER
    DEBUGGING_FILE_HANDLER =
    # DEBUGGING_FILE_HANDLER = /var/log/snmptt/snmptthandler.debug
    [TrapFiles]
    # A list of snmptt.conf files (this is NOT the snmptrapd.conf file). The COMPLETE path
    # and filename. Ex: '/etc/snmp/snmptt.conf'
    snmptt_conf_files = <<END
    /etc/snmp/snmptt.conf.2TTX
    END
    #!/usr/bin/perl
    # SNMPTTHANDLER v1.4
    # Copyright 2002-2013 Alex Burger
    # [email protected]
    # 8/26/2002
    # This program is free software; you can redistribute it and/or modify
    # it under the terms of the GNU General Public License as published by
    # the Free Software Foundation; either version 2 of the License, or
    # (at your option) any later version.
    # This program is distributed in the hope that it will be useful,
    # but WITHOUT ANY WARRANTY; without even the implied warranty of
    # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    # GNU General Public License for more details.
    # You should have received a copy of the GNU General Public License
    # along with this program; if not, write to the Free Software
    # Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
    # http://www.sourceforge.net/projects/snmptt
    # This script is a snmp trap handler for use with the NET-SNMP / UCD-SNMP
    # snmptrapd program and SNMPTT.
    # The script is called by defining a 'traphandle' in snmptrapd.conf.
    # For example:
    # traphandle default /sbin/snmptthandler
    # SNMPTRAPD feeds details about the trap to the launched program's standard
    # input in the following format (see snmptrapd.conf man page for a complete
    # descriptipon)
    # HOSTNAME: The name of the host in question that sent the trap
    # IPADDRESS: The IP address of the host that sent the trap
    # VARBINDS: A list of variable bindings that describe the trap and
    # the variables enclosed in it.
    # SNMPTTHANDLER dumps the received traps into a directory to be processed
    # by the SNMPTT daemon.
    use strict;
    # Process command line arguments
    use Getopt::Long;
    use Time::HiRes qw(gettimeofday);
    my $version = '';
    my $debug = '';
    my $help = '';
    my $ini = '';
    my $debugfile = '';
    GetOptions ('version' => \$version,
    'debug:i' => \$debug,
    'debugfile=s' => \$debugfile,
    'help' => \$help,
    'ini=s' => \$ini);
    if ($version)
    &showversion;
    exit(0);
    if ($help)
    my $USAGE = qq/Usage:
    snmptthandler [<options>]
    Options:
    --debug=n Set debug level (1 or 2)
    --debugfile=filename Set debug output file
    --help Display this message
    --ini=filename Set configuration file to load
    --version Display author and version information
    &showversion;
    print $USAGE;
    exit(0);
    my $DEBUGGING;
    my $DEBUGGING_FILE;
    my $debugcmdline;
    my $debugfilecmdline;
    if ($debug >= 1)
    $DEBUGGING = 1;
    $debugcmdline = 1
    if ($debugfile ne '')
    $DEBUGGING_FILE = $debugfile; # commandline overpowers snmptt script
    $debugfilecmdline = 1;
    # Load config file start
    # For Linux / Unix, try /etc/snmp/snmptt.ini first, /etc/snmptt.ini second.
    # For Windows, try %SystemRoot%\snmptt.ini only.
    my $configfile;
    if ($ini ne '')
    $configfile = $ini;
    else
    if ($^O ne "MSWin32")
    $configfile = '/etc/snmp/snmptt.ini';
    if( open( CONFIG, '/etc/snmp/snmptt.ini' ) )
    close CONFIG;
    elsif ( open( CONFIG, '/etc/snmptt.ini' ) )
    $configfile = '/etc/snmptt.ini';
    close CONFIG;
    else {
    $configfile = $ENV{'SystemRoot'}."\\snmptt.ini";
    my $spool_directory;
    &loadsnmpttini;
    # Pull in passed SNMP info from snmptrapd via STDIN and place in the array @tempvar
    # Create file in spool directory based on current time
    my ($s, $usec) = gettimeofday;
    # Pad the numbers with 0's to make sure they are all the same length. Sometimes the
    # usec is shorter than 6.
    my $s_pad = sprintf("%09d",$s);
    my $usec_pad = sprintf("%06d",$usec);
    if ($DEBUGGING >= 1)
    if ($DEBUGGING_FILE ne '')
    open DEBUGFILE, ">>$DEBUGGING_FILE"
    or warn "Could not open debug output file ($!)";
    select DEBUGFILE; # Change default output to debug file
    # Print out time
    print "SNMPTTHANDLER started: ",scalar(localtime),"\n\n";
    print "s = $s, usec = $usec\n";
    print "s_pad = $s_pad, usec_pad = $usec_pad\n\n";
    print "Data received:\n\n";
    my $spoolfile = $spool_directory.'#snmptt-trap-'.$s_pad.$usec_pad;
    unless (open SPOOL, ">$spoolfile")
    print "Could not write to file file $spoolfile! Trap will be lost!\n";
    die "Could not write to file $spoolfile! Trap will be lost!\n";
    print SPOOL time()."\n";
    while (defined(my $line = <>))
    print SPOOL $line;
    # Print out item passed from snmptrapd
    print $line."\n";
    sub showversion
    printf "\nSNMPTTHANDLER v1.4\n";
    printf "(c) 2002-2013 Alex Burger\n\n";
    sub loadsnmpttini {
    use Config::IniFiles;
    my $cfg;
    if( open( CONFIG, $configfile ) ) {
    close CONFIG;
    $cfg = new Config::IniFiles( -file => $configfile);
    else
    if ($DEBUGGING >= 1) {
    print "Config file ($configfile) could not be loaded\n";
    warn "Config file ($configfile) could not be loaded\n";
    exit(1);
    if (! $cfg)
    print "Error in config file - please check the syntax in the config file\n";
    exit(1);
    # DaemonMode
    $spool_directory = $cfg->val('DaemonMode', 'spool_directory');
    # Debugging
    if ($debugcmdline == 0) {
    $DEBUGGING = $cfg->val('Debugging', 'DEBUGGING');
    if ($debugfilecmdline == 0) {
    $DEBUGGING_FILE = $cfg->val('Debugging', 'DEBUGGING_FILE_HANDLER');
    $cfg->Delete;
    # Defaults Start
    if (! defined ($spool_directory)) { $spool_directory = '/var/spool/snmptt'} ;
    if (! defined ($DEBUGGING)) { $DEBUGGING = 0} ;
    if (! defined ($DEBUGGING_FILE)) { $DEBUGGING_FILE = ''} ;
    # Defaults End
    # print "Config file loaded\n";
    # Load config file end
  • Hamardaban
    • May 2019
    • 2714
    https://www.zabbix.com/documentation...types/snmptrap
    When SNMPTT is configured to receive the traps, configure snmptt.ini:
    1. enable the use of the Perl module from the NET-SNMP package:
      net_snmp_perl_enable = 1
    2. log traps to the trap file which will be read by Zabbix:
      log_enable = 1
      log_file = [TRAP FILE]
    3. set the date-time format:
      date_time_format = %H:%M:%S %Y/%m/%d = [DATE TIME FORMAT]
    PS
    When you publish the configuration files, please REMOVE the comments!
