Getting flapping even with hysteresis implemented
  • trudesea
    • Feb 2015
    Hi all,
    So I've read the docs on triggers and I have a disk space percentage free trigger that looks like this:
    ({TRIGGER.VALUE}=0 and {Template OS Windows:vfs.fs.size[{#FSNAME},pfree].last(0)}<10) or ({TRIGGER.VALUE}=1 and {Template OS Windows:vfs.fs.size[{#FSNAME},pfree].last(0)}>20)
    I would assume I'd get one trigger / email when the free space goes below 10% and a recovery after it goes over 20%. Unfortunately I'm getting one each minute. How can I stop this from occurring?
    thanks for any input
  • ingus.vilnis
    • Mar 2014
    • 908
    Please check your trigger configuration and that you have NOT checked Multiple PROBLEM events generation
    If checked, you will get a message every time the disk space is checked and below 10%.
    Hope this helps!
    Best Regards,
    Ingus
    • trudesea
      • Feb 2015
      Hi Ingus,
      Actually that's the first thing I made sure was unchecked, and it was unchecked. Other triggers are not doing this so it has me a bit confused.
      • harmonica
        • Jan 2009
        • 251
        Originally posted by trudesea
        Hi all,
        ({TRIGGER.VALUE}=0 and {Template OS Windows:vfs.fs.size[{#FSNAME},pfree].last(0)}<10) or ({TRIGGER.VALUE}=1 and {Template OS Windows:vfs.fs.size[{#FSNAME},pfree].last(0)}<19)
